John_Mc
Elite Member
- Joined
- Aug 11, 2001
- Messages
- 4,824
- Location
- Monkton, Vermont
- Tractor
- NH TC33D Modified with belly pan, limb risers & FOPS. Honda Pioneer 520 & antique Coot UTV
I'm going to be installing a trailer brake controller on my TC33D tractor to run the electric brakes on my Metavic M95 log forwarding trailer and on my dump trailer. The tractor is set up for working in the woods, and I do have hills and paces where traction is not the greatest. The trailer brakes will help keep me from getting pushed around when going downhill with a heavy load. The previous owner of the Metavic mounted a brake controller on his tractor. Since the tractor has no brake light, there is nothing to trigger the controller, so he just used the manual activation lever on the controller.
Using just the manual control lever is my plan as well. However, I am also considering trying to rig up something slightly more automatic than just sliding a lever and holding it at the level of braking I need (which would require constant use of one hand any time I'm braking). I could rig up a push button or switch as a kind of simulated brake light circuit to trigger the brake controller. Depending on the model, the orientation of the brake controller is critical to it's proper operation. I'd probably go with a time-delay controller, rather than proportional, since the time delay tends not to be orientation-sensitive.
Has anyone here mounted a brake controller on their compact tractor? If so, what was your experience? Any tips to consider? What did you do to keep the weather and muck off the controller (everyone I've seen is designed to be mounted inside a vehicle).
