Snow Install 54" blade on 2320
   / Install 54" blade on 2320 #1
Elklakedoug
John Deere 2320
Dealer dropped off the 54" blade for my 2320 - didn't have time to install it, told me it was "simple". Could you give me a few points, as I've yet to do it, and would love some wisdom.;)
   / Install 54" blade on 2320 #2
Do you have the quick hitch already? Or was that dropped off too?
There should be an installation section in the manual, assuming there is a manual.
Both the quick hitch and the blade snap right on, unless the 2320 is different from other sub compacts
   / Install 54" blade on 2320 #3
it should be 3 pieces for the blade, not counting the front
attaching support plates (they bolt to the front side frame
of the tractor)
there's a box type part that pins into the above mentioned
front support kit.
then the front hitch pins onto that,
and the blade goes on the hitch, all with
quick pull pins and no tools (except for the
front support kit)
hydraulic lines hook up where loader couplers are,
color coded (although a running change may leave you
with reb/blue on tractor and not the blade)
if everything is in boxes, that's another story,
you will have to assemble the hitch with the cylinders.
thanks! appreciate it - had our first snow last nite....
Year: 2016 Make: Ford Model: Taurus Vehicle Type: Passenger Car Mileage: Plate: Body Type: 4 Door (A55853)
Year: 2016 Make...
2019 INTERNATIONAL DURASTAR 4300 REEFER BOX TRUCK (A58214)
2019 INTERNATIONAL...
2008 GMC C7500 CREW CAB FLATBED DUMP TRUCK (A57192)
2008 GMC C7500...
DEUTZ MARATHON 60KW GENERATOR (A58216)
DEUTZ MARATHON...
1111-A (A54756)
1111-A (A54756)
Genie GTH 844 Telescopic Forklift (A57148)
Genie GTH 844...
