Insight on buying a mini excavator vs renting
   / Insight on buying a mini excavator vs renting
Type wise the cx 36 uses a axial piston pump that puts out two separate flows of 10gpm each, then piggybacked to that a gear pump that puts out about 5gpm that supplies your swing motor and blade. Pretty sure that gear pump also adds supplemental supply to your boom and arm cylinders, it's known to be a good system. As far as OEM manufactures of the pumps they all seem to keep that somewhat of a secret but I think that 36 may use a Bosch/rexroth. Whatever brand of pump used as long as the hyd oil is kept clean, not allowed to overheat and run at a reasonable speed they should go for many hours.
I appreciate that insight. Thank you
   / Insight on buying a mini excavator vs renting #172
You can rent one from MB tractor. They also sell the rental units...
   / Insight on buying a mini excavator vs renting #173
You guys anywhere near Barrington? Liberty International?
   / Insight on buying a mini excavator vs renting #174
I haven't had the best luck with MB....they don't seem interested in responding back to me. I reached out to them about that U25 posted a little ways back and have yet to get a response. Called and emailed.
   / Insight on buying a mini excavator vs renting #177
Wow I have good luck with them.....
   / Insight on buying a mini excavator vs renting #179
Ya that dealer is in Manchester, That's just a small satellite yard....
   / Insight on buying a mini excavator vs renting #180
OK, I might need ya. Gotta get one piece sold, then maybe onto something up your way. May never happen.
Sorry for off topic-back to minis
2018 Chevrolet Equinox AWD SUV (A55758)
2018 Chevrolet...
2021 CHEVROLET SILVERADO 2500HD (A55745)
2021 CHEVROLET...
Kivel Pallet Forks (A53316)
Kivel Pallet Forks...
(INOP) JOHN DEERE 730 CRAWLER TRACTOR (A51243)
(INOP) JOHN DEERE...
40" WIDE STAIRCASE W/ METAL RAILING (A54757)
40" WIDE STAIRCASE...
Demco 365 Gravity Wagon (A50775)
Demco 365 Gravity...
