Injector Timing Pump Question
/ Injector Timing Pump Question #21
</font><font color="blue" class="small">( Hey guys.. I saw the last post for the drip timming tool.. That may well be an answer but $80 for a 1 time use thing is a tough bullet to bite though )</font>
You misread. The $100 Harbor Freight injection system test kit is on sale right now for $80. Apparently you missed the link to the Harbor Freight online catalog. The drip timing device in the photo is a $25 Mercedes part.
My Jinma book specifies for the Y385
"Advance angle of supply fuel supply/speed (before TDC)
10 (+/-1) @ 3000 rpm
18 (+/-1) @ 2800 rpm
16 (+/-1) @ 2600 rpm
15 (+/-1) @ 2400 rpm"
That's RPMs, not static.
Consider that this Y385 motor is put in a number of tractors of varying horsepower. It's rated to put out from 19.2 KW (25.7 HP) to 24 KW (32.2 HP) between 2400 and 3000 RPM. To me, that equates to the three cylinder versions of the JM25x, the JM28x, the JM30x, and the JM35x.
So as you can see, the HP generated is pretty much dependant upon the governor setting; same engine - more RPMs, more HP. To determine which timing point is appropriate for your tractor, consider your governed RPMs. First place I'd look is for a red line on your tach.
Oh, and that the 3000 RPM timing number might be a misprint in the manual. Simple linear progression suggests that the timing mark should be 20 degrees BTDC, rather than the stated 10 degrees.
//greg//
Greg,
I really like the drip concept. I assume it works something like this, attach to #1. Start engine, start stopwatch for 10 seconds, count drops, divide by 10. ****** or advance to get desired number timing point X.
Problems:
Since timing is a static RPM reading does the engine need to be running at recommended RPM to properly set timing?
How do we determine the X in the equation? Meaning is it .5 drops per second or 1 drop per second.
On a side note, I am thinking to heed Harry's advice to go ahead and change the thermostat. Does anyone know the crossreferrence numbers? Also what would happen if I removed the Thermostat? Would the engine just never obtain operating temp? Or would it overheat because all the thermal capacity or the cooling liquid is reduced?
/ Injector Timing Pump Question #23
The drip method I'm sure is with engine off. Just using the primer pump. At least thats how I did it on other type engines.
Without thermostat engine will never reach full operating temperture and will result in lower HP/performance. There are crossover #'s for thermostat, etc here.
http://www.capital.net/~disc1/Filter%20-%20Spare%20Parts.htm
/ Injector Timing Pump Question #25
I must be missing something here with this drip method...maybe someone can help me, but I cannot see how the number of drips will tell you when the injector pump is pumping, only how much it is pumping per revolution?
I would think you would somehow have to monitor crankshaft position.
If it is done with the engine positioned at the desired crankshaft position, how does the pump pump.
Keep in mind that the body of the pump is not rotated, the location of the timing gear is adjusted.
By the way, we had to replace the three washers on the bolts that hold the gear to the hub, those slots take a toll evertime they are tightened.
What we need is a way to trigger our timing lights on the pulse of the fuel through the hard line. Any of you electronic gurus got a way to do this? perhaps by microphone listening to the injector "fire"?
/ Injector Timing Pump Question #26
Bluechip, I must admit I've never had to time one of these Jinma's. I've done probobly a hundred or so other diesels, GM's, Mack, Cummins, Perkins, etc. Mack did years ago use the drip method. Crank was locked at a partucular degree and pump rotated until a specific # of drops were observed in 10 seconds or so from gooseneck pipe. But thats water under bridge.
If I understand what you are saying is,,,,,,the pump cannot be rotated from outside??????? The pump mounting holes are slotted and would allow it to be rotated from exterior. Maybe you're correct as I've stated I've never done a Jinma. Others do it that way though. Please explain as I would like to know.
I've used Kent Moore "Tach n Time" timing tool on GM diesels before and know they are pretty accurate. Here is a link with a diesel timing tool. Don't know much about the quality.
http://www.toolsource.com/ost/product.asp?sourceid=&dept%5Fid=500&pf%5Fid=58061&mscssid=7W4Q8C1E7GHA9PEGA97JUSRHFTNK1LN5
Whoops, /forums/images/graemlins/blush.gif had to edit this........that is a diesel tach for about 200 bucks. The Kent Moore Tach n time is about 900 bucks. Unless you had a shop and did many it is a pretty pricey investment.
Guys,
I hate to ask but in process of getting new thermostat I failed to add new gasket, yep it's leaking.... Does anyone have cross numbers for all gaskets, I will just save it away for future use.
THanks
/ Injector Timing Pump Question #28
Seven corners, sorry about that but don't have a thermostat gasket part #. I'm sure if ya take housing to any big parts store you can find an equivilent. I've matched up misc gaskets like that many times. They usually have a rack of hundreds. You could try the silicone method or make your own but don't recommend it. Hey, when you do find one, post the gasket part # and from where for us guys if you don't mind.
/ Injector Timing Pump Question #29
The drip method is definitely with the engine RUNNING. I only described the IP timing method for my Mercedes 5 cylinder turbo-diesel; once engine timing (BTDC) is confirmed correct, rotate injection pump with engine running till drip tool indicates a consistent 1 drop per second. The concept should be similar for the Y385, I just don't know if it's IDENTICAL.
Seven - cut your own thermostat gasket. Run down to the local NAPA and buy a roll of composite gasket material. That, a scissors, and a hole punch - and you're in business.
//greg//
Well I got the new grade 8 washers, I would recommend to anyone doing the same repair skip the factory washers and buy new ones, at least grade 5.
I redid the whole procedure, starting with #1 @ TDC look for fuel to well..... Timing was as I expected off, It was advanced too far. Reset timing to specs Greg posted. Started it up, it was slightly retarded, bumped it up and wow runs like a champ!! I am totally amazed that I did this repair myself, well with your help, thanks to all that contributed to my post, Greg, Harry, and Chip special thanks..... could not have done it without you's....
/ Injector Timing Pump Question #31
Glad you got up and running again. You did the job, we just did the coaching. /forums/images/graemlins/wink.gif
I'm still at a loss as why can't the pump be fine tuned more easily from the exterior 3 bolts. Maybe I'm being dumb but have done this on many diesels(GM's in particular). The 3 mounting bolts don't go into the gear or the engine would not turn over or the gear would break, the slots in the gear are to get it close and ya should be able to do the fine tune from outside. so come on guys tell me why I'm wrong please.
/ Injector Timing Pump Question #32
Hi Harry,
I tryed to adjust one at the mounting and the hard lines make it very difficult. The manual only outlines the gear slot method. Could be it would work, but as you said, it would be very fine adjustment.
Sevencorners, glad its running well, so when is the Mrs next driving lesson?
Chip,
Funny you asked, she is somewhat afraid to drive it, scared she might break it. I told her no way last break was her fault, I will try and get her on it this weekend. I spent the better part of today using the BB to build a couple of roads, I will snap some pictures later today so you can get an idea of the hills/mountains we have here in VA. The tractor pulls all the hills with out question, I have been going up to the top and knocking down the high spots with the BB, my property is/was part of an old apple orchard so we have all the irritating levels I am trying to grade down the terraces into a more gradual slope. I ran it pretty hard for 4 hours and rechecked all the bolts, amazing just how many were lose. I am thinking of taking the bolts off and putting on locktite next time around. Has anyone done this and what were your results? Oh well it sure is great to play in the dirt!!!
/ Injector Timing Pump Question #34
Please don't use locktite, theres many different types. get the type that is meant to come apart. We use that stuff at work (machine shop) for aircraft parts. You use the wrong type and it will take an act of congress to take apart. I would strongly recommend lock washers whenever possible.
/ Injector Timing Pump Question #35
Seven corners, have to agree with Grumpa with the Loctite statement. There is a place for it but not everywhere.
Things to check for in the loseness department??? For one check the wheel nut torque at regular intervals until they get to their "stretch" point. I've tightened mine twice so far and got a little turn on them, but many have had problems such as a "snapping" or banging noise and found the wheel nuts had loosened up. Could be an unhappy seat time day to lose a wheel. Once they reach that plastic "stretch" region all should be fine. (also check the rim to wheel torque while at it). Heard of one and only one I might add that the hub that the wheel bolts(could have been defective from start or not properly tightened at beginning) to cracked. Could be an isolated case but nonetheless give a tight check. Another place to definately check is the NUT under the steering boot for tightness on front mounted steering cylinders. Several had there linkage loose(could be a real problem to lose steering). I pulled back the boot on mine and get a slight turn, put my mind at ease.
Other than that I can think of no other areas of great concern unless someone else can add to my areas.
I would also recommend changing your factory fluids if not already done so. If you want suggestions on fluid suggestions there are a millinumium worth of reading on this subject so I don't want to go there. LOL. its a lot about personal choices.
Thanks Chip, for the reply about timing the pump from exterior. I follow you about the hard lines. I was really talking fine tune. Done it on GM's and the lines did pose a problem rotating pump. They actually came out with a "pry"type tool that you used with a breaker bar to do just that, which I have used long ago. There was a matching chisel mark and moving it say .020 would equal about 2 degrees so it didn't have to be rotated much, if it did something was mistimed in gear train. If I ever do try it I'll post my insane method. /forums/images/graemlins/wink.gif
/ Injector Timing Pump Question #36
</font><font color="blue" class="small">( and the lines did pose a problem rotating pump. They actually came out with a "pry"type tool that you used with a breaker bar )</font>
Agreed - no LocTite. Wrong tool for the job.
My Mercedes is a 5 cylinder, so four stout hard lines remain connected while the drip tool temporarily replaces #1. Might sound funny, but from that point resort to a 3' crow bar to adjust the pump timing.
//greg//
//greg//
2019 GMC Sierra 2500,4x4 (A62679)
2019 GMC Sierra...
2012 Hyundai Sonata (A62679)
2012 Hyundai...
(12) 4.5"x9' Steel Posts (A66408)
(12) 4.5"x9' Steel...
Cat 312 Excavator (A62679)
Cat 312 Excavator...
2017 WEILER P265 ASPHALT PAVER (A65053)
2017 WEILER P265...
2018 Ford Focus (A61574)
2018 Ford Focus...
