Injector setting pressure
   / Injector setting pressure #1
rabet
malaysia
ferguson
Hi All,
Can onyone please confirm what is the setting pressure for injectors on a perkins AD4.203 engine.
Many thanks
rabet
   / Injector setting pressure #2
There is a DES# stamped into the body of the injector.. that tells the "rebuilder" what nozzle & opening pressure its supposed to be..
It located above the inlet on the injector around the curve.. post the # & I can tell you.. "normally" around 22-2500 psi..
Hi thepumpguysc,
Thanks for reply,
The DES number is 5281613
Thanks Rabet
   / Injector setting pressure #5
He's right about it, you can "play around"' a bit from 2200 to 2500 no harm. I even saw some with more PSI without problems :)
   / Injector setting pressure #6
If you have that "spraying" atomising result when testing PSi you are on the good way, you should get a nice even atomized spray when testing.
As long as you get around 2500 psi all good
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50324)
2018 Toro Grounds...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51219)
2018 FREIGHTLINER...
2018 VOLVO VNL TANDEM AXLE SLEEPER (A51222)
2018 VOLVO VNL...
(INOP) NEW HOLLAND B95 BACKHOE (A50459)
(INOP) NEW HOLLAND...
BE 3 pt Snow Blower (A50514)
BE 3 pt Snow...
