Injector setting pressure
   / Injector setting pressure #1
rabet
Bronze Member
malaysia
ferguson
Hi All,
Can onyone please confirm what is the setting pressure for injectors on a perkins AD4.203 engine.
Many thanks
rabet
   / Injector setting pressure #2
There is a DES# stamped into the body of the injector.. that tells the "rebuilder" what nozzle & opening pressure its supposed to be..
It located above the inlet on the injector around the curve.. post the # & I can tell you.. "normally" around 22-2500 psi..
Hi thepumpguysc,
Thanks for reply,
The DES number is 5281613
Thanks Rabet
   / Injector setting pressure #5
He's right about it, you can "play around"' a bit from 2200 to 2500 no harm. I even saw some with more PSI without problems :)
   / Injector setting pressure #6
If you have that "spraying" atomising result when testing PSi you are on the good way, you should get a nice even atomized spray when testing.
As long as you get around 2500 psi all good
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
IH 445 Square Baler (A50515)
IH 445 Square...
New/Unused 20ft Farm Iron Gate (A48837)
New/Unused 20ft...
2014 MACK GU713 WATER TRUCK (A51243)
2014 MACK GU713...
TAKEUCHI TL8R2 SKID STEER (A51242)
TAKEUCHI TL8R2...
2007 MACK GRANITE ROLL OFF TRUCK (A51222)
2007 MACK GRANITE...
