May 26, 2022 / Injector pump #1 B Boudra New member Joined May 26, 2022 Messages 1 Tractor Kubota l185 If the injector pump is off the engine and the starter switch is engaged, (l185 kubota) is the pump timing compromised when it is reinstalled?
May 26, 2022 / Injector pump #2 ptsg Super Member Joined Apr 3, 2013 Messages 7,780 Location Portugal Tractor Branson F36Rn - Agria 8900D No. On that style of injection pumps that run of the lobes on a cam, the timing is set with shims.
May 27, 2022 / Injector pump #3 T thepumpguysc Elite Member Joined Apr 14, 2010 Messages 3,782 Location South Carolina Tractor Injection Pump Rebuilder No..Shims under the injection pump.. between the pump and it’s mounting block. Just don’t throw them away.!! Why did u remove the pump.?? Leaks.??
