Injector pump
   / Injector pump #1
Boudra
Kubota l185
If the injector pump is off the engine and the starter switch is engaged, (l185 kubota) is the pump timing compromised when it is reinstalled?
   / Injector pump #2
No. On that style of injection pumps that run of the lobes on a cam, the timing is set with shims.
   / Injector pump #3
No..Shims under the injection pump.. between the pump and it’s mounting block.
Just don’t throw them away.!!
Why did u remove the pump.?? Leaks.??
2016 Nissan Pathfinder S SUV (A50324)
2016 Nissan...
2020 Takeuchi TL10V2 (A47384)
2020 Takeuchi...
2005 CATERPILLAR 12H MOTOR GRADER (A51406)
2005 CATERPILLAR...
1995 Chevrolet K2500 Pickup Truck, VIN # 1GCGK29F2SE237154 (A51572)
1995 Chevrolet...
Ford F550 Dump Truck (A47384)
Ford F550 Dump...
