Injector pump question
   / Injector pump question #1
Ben Hucks
John Deere 4050. 6130d
Installed a new injector pump about a month back or so. You guys helped a lot on that. Got another question. My tractor is a 1985 4050 with a 466 non turbo motor. It has a stanadyne rotary pump. What could I expect to gain if I turned it up. I have been told that I can turn it up 10%. What effects will it have on the motor if I turn it up. Just wondering. Any input would be great
   / Injector pump question #2
Does the motor smoke any now under heavy load? If you are reasonable with the adjustment you will gain some hp. If there is no or very light haze under load then I would turn it till you get some smoke. After that you will need to be careful as you can get some high exhaust temps.
Another option is to add a turbo charger. Just buy the kit for 4250 tractor.
   / Injector pump question #3
You have a 27 year old tractor. I take it, that it works OK adding extra fuel, can severely damage a lot of things, besides just the engine.
I would leave it stock, and have a long happy life, get the nozzles tested, that will give you efficiency.
   / Injector pump question #4
The 4050 is about 100 hp so a 10% increase will not hurt the engine or the tractor. They regularly come from the factory 10% over.
2007 Ford Focus Hatchback (A51694)
2007 Ford Focus...
2015 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A53422)
2015 Chevrolet...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2006 John Deere HPX Gator 4x4 Utility Cart (A50324)
2006 John Deere...
2015 CATERPILLAR CT660 TANDEM AXLE DUMP TRUCK (A54313)
2015 CATERPILLAR...
CUSHMAN HAULER PRO GAS GOLF CART (A51406)
CUSHMAN HAULER PRO...
