injector pump on 7610s
   / injector pump on 7610s #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
Ok, I'm doing my yearly maint on the tractor this week. HAve done oil, and just got the inner and outter filter in, and replaced a fuel petcock, and ordered a new fuel line. Did fuel filters and cleaned up water seperators.
What's the skinny ont he injector pump. is it one of those that needs an oil change? Manual is remarkably devoid of any real maintenance info.
If it is.. anyone got directions?
this is a 2002 model, and not sure it makes any difference.. but this is the epa certified one.. has the short fuel filter that uses a twist coupler, not the longer spin on fuel filter. That also means that it has the 2 water seperators, one being a fixed metal can.. the other being a standard fuel sediment bowl, also the fuel filter was a water drain...
thanks
soundguy
thanks
Soundguy
As an update.. i just went and re-read the manual to make sure i didn't miss it.
Covered everything frome grease fittings to scheduled maint thru 1200 hrs... all oils, lube, filters, brakes.. etc.. no mention of injector pump. guess i got lucky /forums/images/graemlins/confused.gif and mine is fuel lubed? or lubed via engine ??
in all that lookin i did find a couple lube points i missed the other day!
Also found out that at 24" behind the lift arms, the lift capacity is 56xx# and 64xx # at the lift arms.. etc. not bad...
Load on the fixed drawbar is between 1200 and 3500# depending on if you have it between 9" out or 16" out. Not bad on that either... i think I've found a ' /forums/images/graemlins/wink.gifkeeper'
Soundguy
Cool deal.. thanks for the info. i was leaning that way. but couldn't find anything decisive.
Soundguy
JOHN DEERE 7R210 LOT NUMBER 49 (A53084)
JOHN DEERE 7R210...
2006 JLG 2030ES 20ft Electric Scissor Lift (A51691)
2006 JLG 2030ES...
2007 DOOSAN G80 GENERATOR (A52472)
2007 DOOSAN G80...
NEW Wolverine Skid Steer Bucket Root Rake Attachment 31'' (A53002)
NEW Wolverine Skid...
Year: 2012 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 61,276 Plate: Body Type: 4 (A50324)
Year: 2012 Make...
