Injector pressure of Branson 4720H
   / Injector pressure of Branson 4720H #1
Bob Nelson
Bronze Member
Oakland, MI
Branson 2400h, New Holland TC33d, Ford 1720, Kubota BX2350d
Hello all.
I bought an older Branson 4720H which I believe is a 2007 model. The tractor smokes a lot. Blue smoke but also white. The fellow at the shop I purchased it from (not a Branson dealer) sold it to me as is and thought it might need rings. In going through the tractor, I decided to replace all filters, etc first. It starts a bit hard but runs very good in my opinion. Still smokes a bit when hot. Looks like it might not have been maintained very well. It has 2,900 hours.
In purchasing the filters, etc at the Branson dealership the owner said that I should throughly check the injectors. I asked him if it was possible for it to be injectors as I have always assumed that blue smoke was from bad rings or valve seats. He said he has seen several tractors do what I have described and it turned out to be injectors.
So here I am and in replacing the fuel filter I found NO FILTER!! I cannot believe this. Anyway I have removed the injectors and purchased a injector tester. Does anyone know what pressure the injectors are supposed to pop at? The engine is a Kukje A2300N2-H. Licensed by Cummins in Korea.
Any suggestions will be helpful.
   / Injector pressure of Branson 4720H #2
Hello Nelson,
Accordingly to the service manual for the older 20 series, the injection pressure is Injection Pressure 14710 kPa [2133.5 psi / 150kgf/cm^2]
If you don't have the service manual yet, check the pinned thread on the Branson section. There is a list of all the manuals, the one for your tractor is named: 10-20 Series Service Manual.
That quite alarming that for some reason the fuel filter was removed.
Hello Nelson,
Thanks. I will pick one up. Once the tester arrives I will check out the injectors. I also wonder if the diameter of the cylinders and pistons are the same with and without the sleeved blocks.
Well, I got my tester today and found out a few things. The injector on cylinder 4 opened at 1900 and then at 2100 and back at 1900 so I don't know what that means. Cylinders 2 and 3 opened right about 2100. But cylinder 1 at first opened and then would not open even at 5,000 psi. I took it apart and it looked kind of worn on the little hat thingy. Also a piece of crud in there. Anyway, I put it back together and again it would not open at all.
ALso, 2 of the injectors do not go pop, pop, pop real quick, they just spray continually.
   / Injector pressure of Branson 4720H #6
I am not a diesel mechanic but sure sounds like you need new a set of injectors or figure out how to clean yours. Pretty sure they should not spray continuously.
71058 (A49346)
71058 (A49346)
2017 Nissan Murano SUV (A50324)
2017 Nissan Murano...
2015 CATERPILLAR 272D2 WHEELED SKID STEER (A50458)
2015 CATERPILLAR...
2012 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2012 GENIE...
2013 Chevrolet Cruze LS Sedan (A50324)
2013 Chevrolet...
2014 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51219)
2014 FREIGHTLINER...
