Injector pop testing - what does it tell you?
   / Injector pop testing - what does it tell you? #1
tlj87
PA
JD 4700, Kubota BX2370-1, Kubota RTV1140CPX, Kubota F3060, Club Car Precedent
Can diesel fuel injectors "pop test" OK but still have issues? I took three injectors to the local diesel injection shop. They pop-tested them and cleaned the exterior of each unit and said they were fine. This took about 10-15 minutes while I waited. There was no charge for this other than $3 for new washers. I'm experiencing what I would call nailing type sound that seems to be most audible around 2000 RPM (NH 1630/Shibaura N843) I've cracked the lines on each and can't discern any difference and there is no smoke from the exhaust other than white smoke right upon startup.
   / Injector pop testing - what does it tell you? #2
Sure, its possible..
If in doubt, get them to install new nozzles.
The tests are performed using a downward stoking motion by hand..
Nowhere near the speed of 2000 rpm.
   / Injector pop testing - what does it tell you? #3
Timing issues?
Someone mentioned cold retarded timing in another related thread. I’ve never dealt with adjusting timing before. For reference, here is what I’m hearing: NH 1630 engine sound - YouTube
   / Injector pop testing - what does it tell you? #5
timing should advance when engine is warm, retarded when cold a govorner inside the pump is changing the timing. A pop test is used to determined the predetermined pressure at which each injector fires. there are shims used to balance them out so they all fire within factory set parameters. ive listened to the video again, sounds pretty normal to me, I have 3 diesel trucks a diesel skid steer and a diesel tlb I take care of myself. this isn't a truck engine surrounded by sheet metal and sound deadening material. Most of that engine on those tractors is exposed so you will hear more of the diesel experience.
   / Injector pop testing - what does it tell you? #6
"....ive listened to the video again, sounds pretty normal to me, ..." I agree. Early in the video I hear a clicking that sounds like excessive valve lash but I don't hear it at the end of the video.
   / Injector pop testing - what does it tell you? #7
It tells u what pressure the injector is popping off at ,also the spray pattern, CatD6 here
Box of Transport Ratchet Straps (A59230)
Box of Transport...
2018 Bandit 15XP Wood Chipper (A57453)
2018 Bandit 15XP...
2014 Chevrolet Equinox AWD SUV (A56859)
2014 Chevrolet...
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A57453)
(1) HD 24ft Free...
2016 Cat TL1055D Telehandler (A56438)
2016 Cat TL1055D...
2019Grove 9000-2 115T Crane (A60460)
2019Grove 9000-2...
