injector oil question
/ injector oil question #1
TSMART
central florida
jinma jm 224
I read a post here which says use ISO 100 Campbell Housfield Compressor oil. (jinma 224)
I followed the procedure I downloaded from an old johns tractor page. So I emptied the oil from the reservoir, then set out for ISO 100 Campbell Housfield compressor oil.
Auto parts store did not have it.
Went to Home Depot. Bought " HUSKY AIR COMPRESSOR OIL".
It is manufactured by Campbell Housefield, but NOWHERE does it say ISO 100.
Is this oil OK to use?
/ injector oil question #2
I first used multi-grade engine oil - 5 years ago.
Drained late last year and replaced with hydraulic oil. I suspect that so long as you use a "light" oil, the most important thing is to replace it at least once a year - something I will do from now on.
/ injector oil question #3
Neither oil mentioned here is fit for informed governor service.
But I digress... do whatever you will do.
To someone that puts 600 hrs. a year on their governor, it's no big deal.
But to someone that puts over 600 hrs. a month on their governors it means a lot, and they are more likely to be pretty picky about what they put in them.
The only thing the oil lubricates is the lift pump seal and cam follower, the front seal on the camshaft, the camshaft and plunger contact areas, and the governor. It does not lubricate the injection pumps at all.
/ injector oil question #4
I just run a SAE 30 motor oil in mine. I run 15W40 in the engine and have not had a issue with either.
Chris
/ injector oil question #5
It's probably just fine. ISO100 merely represents the viscosity, the equivalent of 30W engine oil. Oil with an ISO number lower than 100 would likely be too thin.
//greg//
It certainly looked and poured like 30 weight. I hadn't changed the injector oil since I bought the tractor (from dealer) anyway, what came out of the reservoir looked pretty darn clean....but I am told to do this every year. Its easy to do however and only cost like $2.50....
Thanks for the info.
/ injector oil question #7
20 hours per day running time on a chinese tractor - good luck to you, you certainly do need to keep on top of maintenance and oil specs, but at least you have 4 hours down time each day to do so:thumbsup:
I fit in the 600 hours a year bracket and wear my underpants inside my pants:laughing:
/ injector oil question #8
I don't believe the Chinese governors could last in that working environment. I was referring to the Woodward UG-8's and 2301's on the EMD 16-710's that I run. Currently getting ~15,000 hrs. MTBO.
/ injector oil question #9
I did understand that it was a guarded personal put down... but since you know next to nothing about me apart from the fact I have a chinese tractor I simply put it down to childishness. Hence my mocking response. Notice the lack of emoticons on this response.
BTW, what oil do you suggest Superman?? In your eagerness to flame me you never did say.
/ injector oil question #10
Wow! Grommit 10 posts and you already know what everyone else does-
Bob is superman! And may I add a REALLY nice and helpful guy! BTW the search function would have show considerable discussion on what type of oil to use in the injector. Either way welcome!
/ injector oil question #11
BTW, what oil do you suggest....you never did say.
See post from yesterday at 4:05 PM "But I digress... do whatever you will do."
And I would definitely question someone's knowledge about lubricants that wants to put hydraulic oil in a fuel injection pump and governor. No flame intended.
/ injector oil question #12
QUESTION my knowledge when ever you want (you most likely know more than me about diesels) but I never claimed it to be knowledge. It was clearly stated as my opinion.
I am sure your a great bloke in person.
/ injector oil question #13
Hello all. I deal with the govs bob speaks every day My rr got tired of low oil button on the gov kicking so they piped engine oil through and this oil never gets changed . They test it on the 90 day Qs but that is all and these loco have been running close to 50 yrs When a part fails they replace it . They have the same attitude about workers. I have a great deal of respect for bob r and I could not change a p.a. on one of these engines but come on we are talking about a over grown garden tractor here.I quit postin on this site because of the a know it all that has an opinion on all repairs. Hi greg ! Standing By joe
/ injector oil question #15
I used "compressor oil" when I first got my tractor 5-1/2 years ago.
Now, I use the same as the engine oil in the injector pump. I use 15w/40 diesel oil like Mobil. Sometimes diesel displaces the injector pump oil, especially on the Kama ... not so much the Jinma though. So I do check it and change it frequently, since it's a simple change and only takes ounces of oil.
BTW, Bob Rooks is very respected on the Chinese forums.
He has always posted good information which has been very helpful to many, many Chinese tractor owners, including myself. Just about everyone (like I just did) posts what has been his experience and how they do things. None of them are necessarily "the golden rule", but more so guide lines. And conversely, none of them (generally) are so "bad" to do that it will ruin your tractor. You just have to read and decide which method is best for you. Using the forum with that in mind leads to harmonious discussions and eventually to obtaining useful information.
/ injector oil question #16
They use air compresor oil in the govener on the EMD engines on the rail road I worked on for the last 40 years. The govener on on EMDs is operated by hydraluics and has its own pump and oil supply. The rail road calls it air compressure oil and the barall it comes in says it is hydraluic oil. The 50 weight oil pumped to the govener is to check for low engine oil pressure and operate the load regulator. air compressure and hydraluic oil are low foaming oil...Larry
/ injector oil question #17
True compressor oils are formulated for use in natural gas compressors that usually have contact with carbon dioxide or hydrogen sulfide and will have a viscosity index of ~95, plus an exclusive additive package. I'll bet that's not what you guys are buying. I'll also speculate that if you look closely in the fine print on the Campbell-Hausefield compressor oil you'll see that it is just ISO 150 - same as the "special" Cat pressure washer oil. Marketing must be a fun job, for sure.
Mopacman wrote:
"The 50 weight oil pumped to the govener is to check for low engine oil pressure and operate the load regulator. air compressure and hydraluic oil are low foaming oil".
I thought the rail engines had pneumatic over hydraulic actuators since they are not constant speed. I understand that some of the newer locomotives that have the EMD "H" four cycle engines are using cycloconverter drives. Are those constant speed? last time I looked, the rail engines were still running the Chlorine Free Oil (CFO), but why are they running 50w? What model governors do you have?
/ injector oil question #18
They test it on the 90 day Qs but that is all and these loco have been running close to 50 yrs.
They do oil analysis every 90 days?? We do it monthly! The EMD two cycle engines are chronic oil users (not burners), it's the nature of the beast, but they're getting better all the time. It's typical (for me) to make up 175 gallons in a seven day period. A bad month will see 600 gallons used (worn out packs). Our 710's have a 360 gallon sump plus 50 gallons for the filter, you do the math.
/ injector oil question #19
Not all tractors needs any injector oil maintenance.
As far as I can see, the injector pump on our Foton FT404 tractor seems to be lubricated with the oil pressure coming through a tube from the main engine.
There's no visible oil dip stick, no oil fill cover, no level nor drain plugs on this injector pump.
/ injector oil question #20
Are you sure those are oil lines? Looks like fuel lines to me but I would need to see a wider view picture to be sure.
Chris
2005 SHOP MADE MANIFOLD TRAILER (A60736)
2005 SHOP MADE...
New/Unused 2in Ratchet Strap (A61166)
New/Unused 2in...
INOP/NON-RUNNING 2012 Jaguar XJ Passenger Car, VIN # SAJWA2GE5CMV37496 (A61165)
INOP/NON-RUNNING...
wooden horse rocker (A61569)
wooden horse...
1969 Lincoln Continental Mark III (A56857)
1969 Lincoln...
2017 Ford Escape SUV (A61569)
2017 Ford Escape...
