Injection pump oil
/ Injection pump oil #1
shahan2003
Clifton Forge, VA
Branson 3510
Sirs,
I didnt get any bites on my previous question, so I thought that I would break it down. I have an 2004 3510 Branson Tractor, that works very well. It has a oil screw cap on the side of my fuel injection pump for adding oil. Is this oil supposed to be changed or is it fed from the engine oil? I have found that on some tractors that it is self contained and needs to be non detergent oil.
If it does need to be changed does anyone know where the drain is and what is the correct fill capacity?
Thanks all,
Trac
I did look for an answer and couldn't find a complete answer for Branson.
/ Injection pump oil #2
It is just an alternate oil fill location. Injection pump is lubricated by the motor oil. That motor was made to go into many different applications.
9008SFL (A64556)
9008SFL (A64556)
Car Hauler Trailer (A64556)
Car Hauler Trailer...
2024 MACK GRANITE GR64F DUMP TRUCK (A63276)
2024 MACK GRANITE...
JENDRIX & DIAL UNDERCUTTER, 3PT (A64278)
JENDRIX & DIAL...
2025 Auger Drill Bit Skid Steer Attachment (A64553)
2025 Auger Drill...
7002SFL (A61572)
7002SFL (A61572)
