Injection pump oil
   / Injection pump oil #1
shahan2003
Clifton Forge, VA
Branson 3510
Sirs,
I didnt get any bites on my previous question, so I thought that I would break it down. I have an 2004 3510 Branson Tractor, that works very well. It has a oil screw cap on the side of my fuel injection pump for adding oil. Is this oil supposed to be changed or is it fed from the engine oil? I have found that on some tractors that it is self contained and needs to be non detergent oil.
If it does need to be changed does anyone know where the drain is and what is the correct fill capacity?
Thanks all,
Trac
I did look for an answer and couldn't find a complete answer for Branson.
   / Injection pump oil #2
It is just an alternate oil fill location. Injection pump is lubricated by the motor oil. That motor was made to go into many different applications.
1981 CASE 580D BACKHOE (A51242)
1981 CASE 580D...
2015 KENWORTH T370 QUINT AXLE DUMP TRUCK (A51222)
2015 KENWORTH T370...
2000 TRAILKING TK110HDG-513 LOWBOY TRAILER (A50459)
2000 TRAILKING...
2015 KENWORTH T800 MID-ROOF SLEEPER (A50854)
2015 KENWORTH T800...
2017 FREIGHTLINER 126 SLEEPER TRUCK (A51222)
2017 FREIGHTLINER...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2018 FREIGHTLINER...
