Injection pump install
/ Injection pump install #21
Bummer.!!
I don’t think the engine times at TDC..??
I KNOW the pump doesn’t..
Do u have anything on the valve cover that tells u the timing.?
PMSMECHANIC IS spot on and I’m not telling you to do it any differently than what he wrote, I’m just trying different ideas to make it easier for ya..
Just FYI, the key will be pointing to the #1 cyl..
So if u get your ENGINE TIMED, and the nut and washer removed.. look at the key, say 10:00.. go around to the pump side and look at your #1 cyl to see if it’s close.(2:00)
It sure would be easier if they marked the balancer..
U said the flywheel was marked w a TDC MARK, didn’t you.?? To bad u couldn’t figure it out from there..
It would be nice if it was timed to TDC..
Good luck
Bummer.!!
Good luck
thanks lets see what happens
/ Injection pump install #24
“moved on”...THAT sux..
So he took it off and didn’t know what he was doing..
(Gotta time it first)
Inquiring minds wanna know..how much did u pay him for taking it off.??
U don’t hafta answer if u don’t wanna..
U can send me a prvt msg if u want.
0.00 his decision, had used him several times in the past but he just gave up. tractor has been down going on 2 months now. I think he thought it was like other pumps, not sure.
/ Injection pump install #27
I have one experience somewhat like this so I can help you out to a point.
I was working on a Perkins diesel in a MF 750 combine. I needed to replace the front engine cover and while removing a gear the engine turned and all my carefully set timing marks were useless. So with the verbal help of a diesel shop I got everything back together.
First I found top dead center TDC on the engine by installing a socket under a rocker for a valve (doesn't matter which one) on number 1 piston. Basically you just want to hold it open. Find a pointer on the front cover or make a mark on the front cover. Next you carefully rotate the engine until the piston touches the valve inside the engine. When the piston touches the valve you make a mark (Use a piece of tape or something that is removable) on the front dampener pulley beside the mark you made on the front cover. Then you carefully rotate the engine in the opposite direction until the piston touches the valve again and make another mark on the dampener pulley opposite the mark on the front cover. You should now have 2 marks on the front pulley. Half ways in between those 2 marks is TDC. Carefully measure the distance between the 2 marks and divide it in half. Make a more permanent mark on the front pulley exactly between the two marks and then remove them. You don't need them any more. Remove the socket on the rocker arm as you don't need it any more either. (If your dampener pulley is already marked with timing marks then you don't need to do the above exercise.)
Now you need to go to the diesel shop and ask them to tell you what the timing is on your engine and ask them to set the timing on the injection pump to that specification. Or even better to show you where the timing marks are.
Once you have that info then you can get back to your engine. Now if there are no timing marks on the front pulley then you need to make some. Get a metric seamstress tape measure. Believe me this is way easier in metric!! Wrap it around the front pulley and record that measurement. Say you get lucky and the measurement around the pulley is 360mm. That means that every mm is one degree of rotation. Say the timing on your particular engine is 7.5 degrees. You measure from the timing mark you made on the front pulley 7.5 mm against the rotation of the engine. You want to turn the engine backwards to make this mark as timing is before top dead center. (BTDC). So you aren't lucky and the measurement around the pulley is 245 mm. The math goes like this then. 245 divided by 360 = .6805555. (360 is the degrees in a circle) Next multiply .6805555 x 7.5 degrees = 5.1 mm. So 5.1 mm back from the TDC mark is your 7.5 degree timing mark. Once that is done you line up the 7.5 degree BTDC mark with the mark on the front cover.
Now install the pump making sure all your timing marks are aligned. Also make sure you get diesel fuel into the pump before you start cranking the engine over to start it.
This is all a pretty involved procedure for an amateur mechanic. It would be nice to have the help of someone who knows what he/she is doing. Good luck.
Edited to add that if thepumpguysc get involved with this your in good hands. They are a lot more familiar with this kind of problem than I am.
If you get to work at a Perkins/Massey most all have a rubber plug on the flywheel adapter plate. Remove the plug and as you get to TDC the degree numbers appear followed by TDC. All the gears have dots on that match the next gear. On the 3 & 4 cylinders the pump is driven by a pin Just install the pump and line up the scribe marks. On the 6's once the front cover is installed the oil pump/injection pump is timed by a slot in the vertical slot in the pump adapter plate. Again once those are lined up install the pump and align the scribe marks
/ Injection pump install #28
The other model pump that Delphi (cav) makes (DPA) is simple to take off and put back on..
There’s a missing tooth (master) on the drive hub on the pump..
THAT missing tooth gets aligned with a dowel pin in the drive gear.. and that’s it.!!
150 GALLON FUEL TANKS WITH BRACKETS (A65643)
150 GALLON FUEL...
2024 Kubota SVL 75-3 (A64126)
2024 Kubota SVL...
2022 EZ-GO ELITE...
2014 John Deere 350G Hydraulic Excavator (A64194)
2014 John Deere...
5K Yale Forklift (A63688)
5K Yale Forklift...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A65053)
KNOW BEFORE YOU...
