Injection Issue
/ Injection Issue
Is there any safety switches left in this tractor? Maybe one under the seat? Almost looks like it's a safety switch acting up.
I'm also thing about how the delete was done but I don't think that unplugging the DPF controller would cause shut down issues. You would lose some of the gauges I believe.
No safety switch problems, doesn’t make any difference whether the ECU is plugged in or not. Pump and injectors are strictly mechanical
/ Injection Issue #22
I'm aware. I have the same engine.
/ Injection Issue #23
Does your fuel pump have an external lever for shutting off fuel in addition to the electric shutoff? On my 2400H you physically feel if the stop solenoid is pulled in to run vs dropped out to shut off. If yours is like this it provide a little insite on if solenoid is holding or dropping out.
/ Injection Issue
It does also have a manual shutoff. It is located on the outside of the injection pump below the throttle connections on top. The solenoid shut off stopped working and I have a pull wire attached to the manual shut off.
/ Injection Issue #25
Check to be sure fuel tank vent isn't clogged IE operate engine with shop towel covering fuel tank neck.
/ Injection Issue
Thanks, already checked that, even disconnected the supply line from the tank to make sure it wasn’t clogged up.
/ Injection Issue #27
It does sound like your running out of fuel. Could something be in the tank and not clogging the system until its ran for a bit? Have you tried just having the lift pump suck from a fuel jug?
/ Injection Issue
Getting plenty of fuel supply to the injection pump.
2019 Nissan Kicks Hatchback (A66738)
2019 Nissan Kicks...
2012 WESTERNSTAR 4900FA (INOPERABLE) (A63569)
2012 WESTERNSTAR...
2018 Ford Escape SUV (A66738)
2018 Ford Escape...
AIR HAMMER (A64553)
AIR HAMMER (A64553)
2011 UD Thermoplastic Truck (A64194)
2011 UD...
LINCOLN CLASS 300D WELDER (A67714)
LINCOLN CLASS 300D...
