Injeaction pump
   / Injeaction pump #1
ceg
Garland, Tx
MF130
MF130 with Perkins A4.107 engine. Injection pump has two bleed ports. Generous fuel to bottom port but nothing from the top port. Appears to be blocked. Any suggestions
   / Injeaction pump #2
Hope you can get some help. I have a Massey Ferguson MF 25 with a A4107 engine as well. Great engine but I need to reseal the injector pump as it is badly leaking.
   / Injeaction pump #3
If I recall correctly you need to close the lower bleed and crank the engine before fuel can get to the upper.
2004 Freightliner FL112 Cab & Chassis (A47384)
2004 Freightliner...
TORO TRX-20 WALK BEHIND TRENCHER (A51406)
TORO TRX-20 WALK...
Miller and Smith PNR-1000 Pull-Behind Proof Roller Trailer (A52377)
Miller and Smith...
2016 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A54814)
2016 Autocar...
2012 Ford Escape Limited SUV (A53424)
2012 Ford Escape...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A53422)
2013 Ford F-150...
