Initial thoughts on new BX-2370
/ Initial thoughts on new BX-2370 #1
tractorshopper
Upstate South Carolina
Kubota BX2380
I took delivery of my new BX-2370-1 last Thursday. It replaces my L3800. I sold the L3800 a couple months ago because my dealer told me I'd get more out of a private sale than he could give me in trade. He was correct. I had got a lot of big stuff done with the L3800 and absolutely loved that machine. I will miss her for many reasons, but she got to where she sat in the garage a lot and just wasn't putting enough hours on her to justify keeping her. I do have other things to do that would be nice to have kept her, but the BX will do those jobs (taking more time obviously), and be my regular mower now so it will get used a lot more.
On the new BX, I got the 60" MMM, FEL, a grapple, tiller, BB, and a used bush-hog that I haven't picked up. Also waiting for the tooth bar to arrive to add to the bucket. I've got about 10 hrs on it already. I've hooked up and unhooked every attachment numerous times already and it's pretty easy to do so. I built dollies for all the attachments so I can roll them around the shop and move them as needed. The only thing I haven't built a dolly for is the loader itself. It's just too heavy for wood and Lowe's castors. With it being a smaller machine and even before I put stuff on dollies, it is easier to hook stuff up to because you can manhandle stuff. I had the Pat's quick change on the L3800. I think I would like that again, but I haven't had any problems hooking stuff up on this new one. I don't necessarily like how the turnbuckles are where I have to loosen to get them out and around the pins, then tighten back up each time. System could be a little more beefy. Pat's would let me set one time and never worry about again. I'll say the top link really spins easily compared to the top link on the L though. The loader itself is quicker to remove and rehook. The quick attach on the bucket/grapple is not as quick attach as the one on the L either. I still have to remove pins, but not a terribly big deal.
Cutting: This mows much better than my JD L118 lawn tractor. A lot of times with the old lawnmower, I would have to make 2 passes on stuff to get it all cut even. I know it's early season right now, but this BX has such high blade speed that it doesn't miss anything and I can mow much faster speed-wise and also with the much bigger deck, make a lot less rounds. The deck height is easy to adjust. I mowed at my house and I mowed at my property where I used to bush hog. Just set it a little higher and put the pedal down. It steers like a dream and with 4X4 tackles every hill so much better. I got the rears filled for extra stability down low and it feels like a tank even though it's much smaller than my last tractor. I will easily side hill stuff that I never would on the L and with the mid-deck, I easily get around trees instead of backing up at angles, so it's a fair amount faster there, not to mention gives a really nice finish look. The only real con here is that the top spindle guards on the deck need to have the screws tightened regularly or you will lose them. They were very loose after running at my property and I had tightened them before taking it there after mowing my lawn. Watch for that. Maybe some lock-tite is in order. Also, not so much with my pasture areas, but with the lawn itself, this is a lot heavier than my old lawn mower, so I will have to make sure the ground isn't still damp before mowing so I don't tear it up with the R4's.
Box Blade work: Actually have used it very little on mine so far, but I used my brother's BX25D with identical box blade a couple months ago at his property. I really thought that it would be a joke in comparison, and it is smaller and lighter than what I had, but I was very surprised at how it would pull a full load of dirt. With it being lighter, it doesn't cut right into hard ground quite as good, but with a couple more passes, will get deep. And you can pull the full box with the smaller tractor. This is a 5' box. My old one was 6' and almost twice as heavy, so it would get a very aggressive initial dig comparatively, but this new one does work much better than I thought it would.
Tiller: I got the exact same tiller that I had with the L, but a 50" instead (10" narrower; otherwise identical). I wasn't going to buy one initially. My brother got the lighter 50" LP tiller with the shear pin. I used it at his property and was not impressed at all. The tines are 2" shorter and the shear pins break regularly. I found it frustrating. So when I got mine, I went ahead and spent the extra cash for the RTR1250. I must say, that I did worry about using it being less than a foot smaller, but having 15HP less on the tractor. Well I used it Sunday and did a large area and up a hill (that I ran sideways on as well) that I never would have done with the L. This set-up seemed very much more stable to me. The tiller never zapped too much power and the tractor handled it like a champ. This too me is the biggest surprise so far. I'm going to say that other than being narrower so having to make more rounds, this set-up is better than my last tractor and I'd prefer to do it this way. Actually, for food plotting in small areas, I can see this being a better set up all the way around. I removed the mower deck for this kind of work and any time I didn't want it in the way. Very easy to take off and re-install.
Loader: Obvious drawbacks here, but I knew there would be. The lift weight is surprising for the machine and with rear wheels filled and BB or tiller for ballast on the back, it will handle more than I thought it would. Must be very careful as with any tractor on how high you carry your load if on slopes. Fair amount less capacity overall, but I think very well matched to the machine and still very capable. Just will take a lot longer to move piles, etc. I don't have the tooth bar yet, so don't know how well it will dig, but with it being so much lighter, I suspect it will be acceptable, but lacking in what I'm used to for sure. It's smooth to operate and I didn't notice any real negatives except that I'm used to bigger scoops. The only thing I'll really ding it on here is that I do not like that the angles are less for dumping and curling. The bucket still empties fine, but I'm used to much steeper angles in both directions.
Grapple: Can't compare to the L3800 because I didn't have one with it. This thing is the cat's meow. I had been doing a bunch of pruning and privet cutting and I piled a ton of stuff up at the property in very little time. I'm still learning it and I think there's more functionality that I'm just now figuring out like back-raking to put stuff in a straight line for pickup etc, but this is sweet. You can grab a random stick or piles of stuff. Was easy enough to pick up on the extra two buttons. I'm sure this will get a lot of work over the years and sure beats dragging stuff around by hand or with chains. If something is in your way, you just grab and it put it elsewhere. First thing I did was grab a couple rocks and a cinder block that I put the tongue of my trailer on and move them out of the way to pick up some tree limbs I had cut and been waiting to move until I got this thing.
Overall, so far I believe I have made the right choice. Time will tell. I can see myself wanting a larger tractor again in the future if I ever build and move to my property permanently, but I knew that before I did this. I may actually find that I really won't ever want a larger tractor as I really learn the limits and get good at operating this one. I'm always amazed at reading what folks here do with theirs.
No, I still can't post pics here. Still don't know why it stopped letting me 6 months ago or more. It acts like it's going to upload and just spins and never works. I'd love to otherwise.
Also, sorry so long and sorry about the contractions turning into gibberish. I wrote it in Word, then pasted it here and it went haywire. Didn't look that way until I clicked "submit".
/ Initial thoughts on new BX-2370 #3
Thanks for the review. You would be amazed at the amount of people who count on information like this. Me for one.
/ Initial thoughts on new BX-2370 #4
I have rear mounted DelMarino and Woods mowers for my BX and B. I had 2 John Deeres with the model 47 decks over the years. I always thought the Deere grooming deck was about the best there is. Surprising to hear you like the MMM better!
/ Initial thoughts on new BX-2370 #5
One of the big differences I find with the small tractor is the poor ride quality on rough ground compared to a larger tractor . I could never bush hog all my fields with the 2650 as my fields are a little on the rough side , other than that I love the smaller tractor .
ZionView - it's all about the blade speed I believe. My JD lawntractor did not cut well. Standard 42" deck. I actually had replaced the deck 2 times over the years due to heavy use/broken welds, etc. Even brand new, it never threw grass out the way this MMM does. Not even close. Grass flies out of the MMM no matter how thick and doesn't mat up the way it would on my JD. And because the blades turn so much faster, I can cut faster and not have to go back over dandelions and other weeds numerous times. On top of that, the hydro on the lawn tractor is nowhere near what the hydro on the BX is. Same with the steering ;-)
I'm sure Deere makes some great mowers and I'm sure yours were of that breed, but mine doesn't even come close in comparison to the MMM on the BX. Mine was a standard box store one.
/ Initial thoughts on new BX-2370 #7
:thumbsup: Great review. Keep it up as you use it.:thumbsup:
/ Initial thoughts on new BX-2370 #8
Very well written review. Thanks!
HEC, you are correct. I did notice that it is a little more bumpy in spots at the property. Apparently it didn't bother me too bad though because I forgot to write that up. Seat is plenty comfortable and for a short guy like me, it actually adjusts to fit me better than the L. My L, I had the seat all the way forward to be comfortable. This one, I've got room to go forward or backward still. I'm 5' 7.5"
Others, thanks for replies and reading. Glad you enjoyed the review.
JT, only 20 some more tractors and I'll catch up to you. Of course you'll have bought another 50 in that time. :thumbsup:
/ Initial thoughts on new BX-2370 #10
Couldn't have said it better myself.
I'm beginning to reconsider the BX, as part of my "Two Tractor Solution," so please, do continue with your well-written reviews.
And Congratulations on your new machine!!!
My Hoe
Updating this now after about 10 months. I'll be brief. Much more time on the machine and new learnings. I really stand by my initial post and this is a great machine and still surprisingly capable considering I downsized quite a bit.
I mentioned the dump angles on the loader. I have really got used to this and it's not such a big deal as I initially thought it would be. I have a tooth bar and that kind of extends the bucket, so I can still heap loads and have just gotten used to the smaller overall bite. It's really fine and if I hadn't had a larger tractor before, I wouldn't know any better. I'm still blown away with the capabilities for the size. Really amazing.
I mentioned the turnbuckles in my initial post. Maybe a better more correct term is check chains that I didn't like initially. I eventually got the quick hitch and love it so I don't have to keep adjusting them. The check chains are not nearly as easy to use or sturdy as the L3800. I still absolutely hate the check chains now. Being more flimsy, I have actually broken them 2 times. Both times were doing box blade work and I backed into small trees while not looking too good where I was going, but I didn't think it was excessive force at all. The eyelet bar is welded onto a nut and I broke one side of the eyelet off the nut. I ordered a replacement and fixed it and just recently have now broken the replacement. There are 8 welds on 4 nuts with this set up, so in my estimation there are 8 places susceptible to break. Some may say that's good so it doesn't mess up something else more major, but both that I've broke I didn't feel like I was doing excessive work. I talked to my brother about this and he said he's broken all 4 eyelets doing box blade work. I knew he broke one because I ordered and picked up his first one. Basically, what I'm saying is the check chains are just poor design in my opinion. This week I am ordering the check chains from an L or similar tractor to rectify this problem for good. Both breaks I've done didn't look like the weld went very deep into the nuts and the nuts could also be pretty brittle in comparison to the rest of the design. My L was completely different, easier to adjust, and never had an issue like this and I put it through much more abuse due to it's size and the tractor size that ran it.
The fuel gauge: It reads full for quite a long time, then quickly descends to one bar or zero bars and blinking light. It tricks you into thinking you're low or empty. It has a 6.6 gallon tank, but when the gauge reads empty, I can only seem to put another 3 gallons back in or so. I guess in a way this is good because I've never run it out of fuel.
Since I am also basically mowing what I used to bush hog at my property as well as my lawn, I have worn the mower blades down faster than I thought I would and have put a new set on while they were on sale. This is okay for me. I will sharpen the old set and then rotate when necessary. When the blades are sharp, this thing still puts out the best cut of anything I've ever owned or operated and is so easy and fast.
I have logged a ton of time with the grapple and I'm amazed with it. It will do more than I thought it would by a long shot. I didn't think I'd be able to root anything, but I have rooted a ton with it. Yes, it has it's limitations, but it has been very productive and a lot of fun. Only issue here is the quick hitch for the BX grapple/bucket change is not in a great position. I have bent the tabs while rooting and have to pound them back separated to get the pivot pins back out to swap the bucket and grapple. One could say I'm using it harder than intended though, so I'm really not complaining. I wish the tabs were somehow up higher or out of the way, but that's the way it is. Everything still works fine.
So, long story short, aside from the couple minor negatives, with the check chains being the one main thing I don't like at all, I am still very excited about this tractor and its abilities. I would do it again all things considered and still be extremely happy and impressed.
/ Initial thoughts on new BX-2370 #12
Would the Kubota aftermarket telescoping stablizers be suitable for you? Maybe too big for your 2370, but if not, a lot better than chains or turnbuckles...
/ Initial thoughts on new BX-2370 #13
Those turn buckles were the biggest turn off for me too. Once I got the custom fabbed version from a fellow TBNer, the BX was just about perfect. I wish the fella was still making them. I'm sorry I cannot refer you to another source for them.
I haven't seen the telescoping stabilizers, but will take a look. My plan was to go to dealer tomorrow morning and order a set for an L which I'm more familiar with or at least check out what is on a B first, then decide which to order to replace mine. BP's set up looks very nice.
/ Initial thoughts on new BX-2370 #15
Mark ??? (I've slept since I last mentioned him) made these for a bunch of us on BYC. Again, I sure wish there were others, up to AND including Kubota, who would produce these for you.
The reality is that turnbuckles on the small Kubotas, BXs and small B's should simply not be sold, imho.
/ Initial thoughts on new BX-2370 #16
Don't know how small the BX 3-pt hardware is, but I wonder if the telescoping stabilizers for a B2301 would fit?
/ Initial thoughts on new BX-2370 #17
Gee, mine have been working OK on my BX25, and I use a box blade to fix up a rocky driveway each Spring. (Maybe I'm not being violent enough!)
/ Initial thoughts on new BX-2370 #18
That's fine, man, don't believe anyone said those don't work so keep right on with them, but I can assure you that other's experience, including my own, is largely negative on fussing with turnbuckles. Once you've actually experienced using the telescoping kind, like the all the larger tractors have instead of turnbuckles, you'd never go back, I assure you. Ease of use, stability, speed of changing out an implement; the difference is daylight to dark. Use whatever floats your boat.
/ Initial thoughts on new BX-2370 #19
So where can a guy get a set of those cool telescoping stabilizers? I too have a BX2370 and love it, but I gotta admit, noodling with those turnbuckles is a PIA, just enough for me to not want to swap out an implement.
Cheers,
BN
/ Initial thoughts on new BX-2370 #20
Cheers,
BN
That's the question. Mark Hodge?? I believe his name is, made up these for me and a bunch of other folks a few years back. Last I heard, Mark had quit making them to focus on family life, which is just fine. I've no idea who may have picked up making these. Hopefully, someone knows what the current options are for making, buying or adapting other telescoping versions off the larger Kubotas.
The Kubota BX series is SUCH a high quality small tractor it deserves them.
