Inherited old Rhino 224
   / Inherited old Rhino 224 #1
Rhino224
Alsea, OR
Rhino 224
Hi, I'm new to this site and am about to begin work on a Rhino 224 that was running about 3 years ago. In fact, previous owner used this little tractor to dig fence posts for me at that time. The problem is I now have this tractor and it is no longer running and I could use some help in finding out what the most obvious parts to change or clean might be. What would YOU do first to determine why it won't start. Things I have thought of are removing and checking the fuel tank (clean and dry it out)...finding some online parts place to buy an ignition WITH a key (previous owner connected it manually)...buying an operating manual if one is available somewhere...and maybe buying a solenoid. I already purchased an adequate new battery. I do have a "picture book" parts manual...at least that is something. Well, I hope someone sees my post...and can give me a bit of info I can use to start this project...either with personal advice or telling me of a place that I can order parts for my tractor. Thanks.
   / Inherited old Rhino 224 #2
Welcome to tbn,, you might try looking and searching in the brand specific area of this site,,, Good luck..
   / Inherited old Rhino 224 #3
Do you know if your Rhino is one of the ealy chinese import tractors? I remember some Rhino's were chinese, but from the given information, I have no way of knowing. If you think it is, you might have better luck in the Chinese Tractor sub forum of this site.
Good luck and take care.
Thanks, I am so new here that I didn't even know "brand specific" was available for this less common and older brand.
It does look old, but it has "assembled in the US" on the side of the instrument panel...Will look for a sub forum, as you suggested. Thanks for responding.
2006 DRAGON PRODUCTS 150BBL VACUUM TRAILER (A53843)
2006 DRAGON...
2014 INTERNATIONAL DURASTAR 4400 SERVICE TRUCK (A51406)
2014 INTERNATIONAL...
2017 Ford Fusion Hybrid Sedan (A53424)
2017 Ford Fusion...
2013 Ford F-550 Ext. Cab 4x4 Auto Crane 6406H 6,400LB Crane Service Truck (A53422)
2013 Ford F-550...
Adams 6T Fertilizer Spreader (A53473)
Adams 6T...
2017 KENWORTH T880 (A53843)
2017 KENWORTH T880...
