3-Point Hitch inherited b20 from gramps
   / inherited b20 from gramps #1
sauto1985
pinckney,michigan
kubota b20
i inherited a b20 from my gramps a 3 years ago---- but could never find the 3 point lift arms at his barn does any one have one or know the specs---ive been looking on ebay ,many different sizes? thanks
   / inherited b20 from gramps #4
There may be a kit available from Kubota. Worth checking with a dealer... he should be able to look it up for you. It'll be more than those eBay kits, no doubt.
Also, even though the B20 is out of production, there are still plenty of them around. If you could find another one, maybe you could at least get some measurements to see if one of those generic kits would work.
Finally, maybe a tractor salvage place would have something. Here's one I found online; there are also many others:
Kubota Tractor Parts: Engine Parts || Weaver's Compact Tractor Parts & Compact Tractor Salvage
thanks, ill check salvage tractor place ---- the dealer told me over 900. i thought that was too high
   / inherited b20 from gramps #6
All the parts are still available from Kubota, but would have to be ordered separately from the parts dept. You can get a parts manual online here:
Index of Kubotabooks/Tractor Parts Manuals/
The lower links for the B20 cost about $270 whereas the ones for the B21 only cost $76. My guess is they would fit since it was a very similar model just a little newer. Probably any of the 3pt hitch parts from similar sized B-series would work. Top links should be the same for most of the B-series, and the side links should be similar or could be modified.
   / inherited b20 from gramps #7
I looked over a B21 after getting my B20, and it looked to me that just about everything on the B21 was smaller and less robust. I'd be real sure of a fit before spending any money.
$.02 ,
Dennis
$.02 ,
Dennis
thanks for info --- i bought a pair of new over stock kubota arms off ebay for 49. for the pair plus shipping= 85 total and some aftermarket vertical lift arms and stabilizer chains for another 80. and good to go------these arms measured close to a forum members b20 on orangetractor forum just need to drill holes fore stabilizer chains
:thumbsup:
Ingersoll Rand SD-116DX TF (A53317)
Ingersoll Rand...
2012 OVERLAN KILL TRAILER (A53843)
2012 OVERLAN KILL...
TANK MANIFOLD (A55745)
1604 (A57192)
1604 (A57192)
Pratt 8.5ft Flatbed Tilt Trailer (A55787)
Pratt 8.5ft...
JOHN DEERE 5125R LOT NUMBER 24 (A53084)
JOHN DEERE 5125R...
