Inground Pool Phase 1
/ Inground Pool Phase 1 #1
Timber
East Bridgewater Massachusetts
Kubota B7800
The 1st thing I have to do is take down my above ground pool
I cut the center supports completely out, I use a floor jack to hold the wt. so I didn't pinch my chainsaw bar. The I went around the perimeter supports and cut the 3/4 through top and bottom. Chained up to the tractor and away I went.
the next step is to dig out all the sand under the in ground pool, I want to save it because I will reuse it under the liner I will use for my Coi pond
My wife hasn't quite got the hang of a digital camera yet. that one is a little fuzzy
[URL=http://i113.photobucket.com/albums/n235/Timber_8/000_0184Medium.jpg]
[/URL]
The very rare pic of Mrs Timber, You should feel very special
This is the sand pile I took out of the pool area
Now I am going to continue with the last posts that I left out so I could drag the deck through and dig the bottom sand out and pile it out of the way
Dam thats all for today, its starting to rain, so time to put everything away
/ Inground Pool Phase 1 #4
And here i was SURE Mrs. Timber didn't really exist !!
Nice job ! Almost looked a little fun !
/ Inground Pool Phase 1 #5
Timber,
That shevel by the deck is looking like it is getting rusted. I bet it doesnt get the use that it did to before the B7800. I think that it is getting alittle upset with the tractor. You better not store them together, you never know what may happen!!
Projects are looking good. It is funny how they are more fun to do with the tractor.
LOL they are a lot of fun. I have been having a great time with my tractor, I don't know how I would manage my property without it
/ Inground Pool Phase 1 #7
I'm curious to see this project. Hope you keep posting all the way through Timber. Looks great so far!
We had a little bit of a set back, Seems the contractor or the building inspecter did the wrong permit and now it has to go through the conservation commity for a hearing because I have wet lands. It is not going to be a problem but more of a formality. It is actualy working out for me as I am getting more done than I expected
This area is above the pool and the contractor wanted to raise the pool 2 feet out of the ground and build up the area with the soil that came out of the hole. Now I want to pool to sit flush with the landscape I don't really want a raised pool. So I dug all this soil out so it doesn’t run off into the pool
Well now the tractor has done its part. I have removed most of the material and now have a nice pile of rich soil that I need. Now the rest has to be done with a spade, square shovel and several different rakes! The tractor can't do every thing
Well I have everything all graded out and this part is done. The plan is to build a deck the length of the house so it should be 55 feet by 16 feet + depending on where the pool apron actually windes up. Well I have neighbor’s coming over to grill and sit by the fire pit so time wrap it up a fair days work
2021 CATERPILLAR 420XE HRC BACKHOE (A65056)
2021 CATERPILLAR...
Kubota L175 Tractor (A62613)
Kubota L175...
2014 MAGNUM TRAILER (A68842)
2014 MAGNUM...
Sandblast Pot (A68134)
2025 20in. Rotary Brush Cutter Mini Excavator Attachment (A66734)
2025 20in. Rotary...
2011 UD Thermoplastic Truck (A64194)
2011 UD...
