Inground Pool many Pics
   / Inground Pool many Pics #1
Timber
East Bridgewater Massachusetts
Kubota B7800
this is the plumbing trench for the pump house
This is the power trench
A days work done
Hear they are starting to set up the mettal walls
Some shaping of the inside
Hear they are back filling the outside to get ready for cement
cement guy is hear
working cement around the outside to hold pool in place
Shaping the inside
Now this is a soft cement that goes under the liner
there is a foam liner on the metal walls
Hear they are pulling the liner
there is a vacume set up to draw the liner tight as it fills
Setting the bottom drain
vacume
This is all the plumbing to the pumps
from the pool
to the pump and filter
this is about were the filter will be
This is as far as we are to date
   / Inground Pool many Pics #7
Timber,
WOW, great pics!!!
Can you give some specifics? What size is it? How many gallons? What are your requirements for power and water?
From the look of your pics, it looks like you're going to build a wood deck around it. Is that correct? What's the plan for that?
Thanks,
Eddie
   / Inground Pool many Pics #8
Looks good to me and I have built hundreds of them. That is a pretty fair representation of what you have to do to install an in ground pool except you didn't show any pics of a shovel. Befote my son took over it was just the 2 of us and we dug the pools with a 863 Bobcat. We would dig the first day, shape , set walls and pour footings the second. Trowel the botton and install liner and plumbing and start filling the third. We would generally take the forth day and go install a couple of above ground pools while the pool was filling from the owners water hoses. It would cost the homeowner 30-40 bucks for county water, while having it trucked in was more like 800.00. We would come back on the fifth day and backfill. Now he does them every other day by having the water trucked in. It cost the homeowner more but he feels that he can make more money per pool by doing it that way. I'm from the old school and tried to save the homeowner every dollar I could, but he makes more money than I ever did and works less, so I guess I'm the one who had it wrong. Later, Nat
   / Inground Pool many Pics #10
its like an above ground -in ground pool....
weird never seen it done that way before.
every inground pool ive ever swam in has either been a 1 piece fiberglass versioin or the kind were the line the dirt shape with rebar and blow in the concreet. no liner.
2003 Chevrolet 3500 (A50120)
2003 Chevrolet...
2014 KENWORTH T800 MIXER TRUCK (A53843)
2014 KENWORTH T800...
2017 Taylor-Dunn B0-248-36 Electric Utility Cart (A50324)
2017 Taylor-Dunn...
2001 CATERPILLAR 140H VHP MOTORGRADER (A51406)
2001 CATERPILLAR...
2021 KENWORTH W900 TANDEM AXLE SLEEPER (A54607)
2021 KENWORTH W900...
safety baskets (A53421)
safety baskets...
