inground pool heaters
   / inground pool heaters #1
TAB
Bronze Member
MI
L35 TLB
Hello, I've been away for awhile. We are looking at buying a 200,000 to 250,000 BTU LP inground pool heater. Does anyone have any recommendations on brands to buy or not buy? Would appreciate any info anyone might have.
Thanks, Tom
   / inground pool heaters #2
We've only had ours since last Aug so I don't know if our experience will mean much. The builder recommended we stay away from the new electronic ones (with the fancy led display, programmable, etc.) as the circuit boards or something were not holding up well to the elements. Off the top of my head, I can't recall the brand we got (I'll kick myself when I go look as it is a major brand name) but it is a 400,000 BTU unit that heats the water well, comes on when its supposed to, and really runs my gas bill up. I think these things (non-electronic ones) are pretty low-tech appliances that should be fairly reliable. Probably shouldn't require alot of research.
   / inground pool heaters #3
Wish I could just send ya'll some of my excess warm water. As of May-15, mother nature has taken my pool temp up to ~90F!
RET
   / inground pool heaters #4
90? Is that all? That's the temp my kids want. Anything less and we have the heater going. They think the pool is a giant bathtub.
   / inground pool heaters #5
I heat the pool with my Taylor Wood Burner. I did a little creative plumbing, so I can switch-over the hot-water heater coil to heat the pool.
If I put the pool cover on and run the Wood Burner hard overnight, I can raise the pool temperature a couple of degrees.
It works OK and hardly cost me a cent /forums/images/graemlins/wink.gif
See: Taylor WaterStove
   / inground pool heaters #6
Pool temp will hit 96-97 deg. by end of June.
At that temp, you have to get OUT of the pool to cool off!
RET
JOHN DEERE 408R (A53084)
JOHN DEERE 408R...
2002 Wacker RD11A Tandem Smooth Drum Roller (A51691)
2002 Wacker RD11A...
2021 CHEVROLET SUBURBAN (A53843)
2021 CHEVROLET...
THE HANDLER II MIXER UNIT (A53843)
THE HANDLER II...
2012 Ram 1500 Crew Cab Pickup Truck (A53422)
2012 Ram 1500 Crew...
2010 Lincoln MKS (A50324)
2010 Lincoln MKS...
