Ingersoll 4020 Won't Start
   / Ingersoll 4020 Won't Start #1
smartdog
No Stonington, CT
Kubota 3240
My 1997 tractor won't start. Battery is good. When you turn the key, the starter would click, but that's it. Sounded like a solenoid issue, so I bought a new starter-still same thing, just a click.
Doesn't seem to be the neutral safety switch, as it does click. PTO is off. Any Advise?
I removed battery cables & cleaned them very well. Also sanded the ground & starter connections. Check the battery voltage with a meter, all ok. Pulled the starter & tested, ok. Finally called the shop. They came to look at it: an hour later they said, can't find anything wrong, other than it won't start. I'll have to load it & bring it in.
After quite a few hours on it, they repaired a number of wires, & replaced the key switch. I had mice which chewed the wiring in a few spots, which required a lot of disassemly to get at. Big repair job, & big bill.
   / Ingersoll 4020 Won't Start #4
Thanks for the update.
Hope they can fix it quick. :thumbsup:
LOL, that's what I thought about the starting.
Since most of the wiring/grounds/connections have been checked, I'm going to try a regulator.
Spent more than $1000 on it over the last few years, and I only use it for splitting wood.��
   / Ingersoll 4020 Won't Start #8
Instead of buying a regulator, why not use your multimeter and find out if it is working?
   / Ingersoll 4020 Won't Start #10
Start with the voltage measured on the battery posts, not the cable clamps.
Then start the engine and see how much it goes up.
I don't know what type charging system your tractor uses, but this might help: YouTube
2014 DRAGON PRODUCTS 130BBL VACUUM TRAILER (A53843)
2014 DRAGON...
2021 CATERPILLAR D4 LGP CRAWLER DOZER (A51246)
2021 CATERPILLAR...
1985 Ford Ltl9000 Tender Truck (A53473)
1985 Ford Ltl9000...
2007 FREIGHTLINER BUSINESS CLASS M2 DUMP TRUCK (A51406)
2007 FREIGHTLINER...
1988 Kenworth W900B Dump Truck with 3406B CAT (A53473)
1988 Kenworth...
2012 CHEVROLET 2500 HD SERVICE TRUCK (A51406)
2012 CHEVROLET...
