Ingersoll 4020 Won't Start
   / Ingersoll 4020 Won't Start #1
smartdog
No Stonington, CT
Kubota 3240
My 1997 tractor won't start. Battery is good. When you turn the key, the starter would click, but that's it. Sounded like a solenoid issue, so I bought a new starter-still same thing, just a click.
Doesn't seem to be the neutral safety switch, as it does click. PTO is off. Any Advise?
I removed battery cables & cleaned them very well. Also sanded the ground & starter connections. Check the battery voltage with a meter, all ok. Pulled the starter & tested, ok. Finally called the shop. They came to look at it: an hour later they said, can't find anything wrong, other than it won't start. I'll have to load it & bring it in.
After quite a few hours on it, they repaired a number of wires, & replaced the key switch. I had mice which chewed the wiring in a few spots, which required a lot of disassemly to get at. Big repair job, & big bill.
   / Ingersoll 4020 Won't Start #4
Thanks for the update.
Hope they can fix it quick. :thumbsup:
LOL, that's what I thought about the starting.
Since most of the wiring/grounds/connections have been checked, I'm going to try a regulator.
Spent more than $1000 on it over the last few years, and I only use it for splitting wood.��
   / Ingersoll 4020 Won't Start #8
Instead of buying a regulator, why not use your multimeter and find out if it is working?
   / Ingersoll 4020 Won't Start #10
Start with the voltage measured on the battery posts, not the cable clamps.
Then start the engine and see how much it goes up.
I don't know what type charging system your tractor uses, but this might help: YouTube
Vermeer Chipper BC900 (A52377)
Vermeer Chipper...
1264 (A50490)
1264 (A50490)
2012 WABASH 53' DRY VAN TRAILER (A53843)
2012 WABASH 53'...
2012 UNVERFERTH 15-INCH REAR SPACERS FOR 10 BOLT HUB (A53473)
2012 UNVERFERTH...
2016 Godwin CD150M 6in Dri-Prime Pump S/A Trailer (A51691)
2016 Godwin CD150M...
(NEW) 2025 DOWN 2 EARTH GOOSENECK TRAILER (A51247)
(NEW) 2025 DOWN 2...
