Infrared Thermometer will it read a corrugated flue pipe
   / Infrared Thermometer will it read a corrugated flue pipe #1
goeduck
Super Member
Kitsap, WA
Kubota, Massey, Iseki
Flue pipe on my wood burning fireplace insert is corrugated SS and barely visible through the cut out heatilator tube. I would like to know the temp of the liner at this location which is about 18” above the insert. I have read that stainless is hard to read due to its emissivity and I can’t really get to it to paint it black.
Would an infrared thermometer work? I was looking at a Fluke 62
   / Infrared Thermometer will it read a corrugated flue pipe #2
should work...I have Nub8380H (looks very similar to the Fluke) and use to check hot spots on the bbq grill and have played with it shooting in the burning FP...
   / Infrared Thermometer will it read a corrugated flue pipe #3
Yes and no. it will read, but incorrectly due to the reflective aluminum surface. You would need to put a dark, non-reflective "something" on the pipe. Black stove paint would work. Just on a small area where you would read. It is all related to the emissivity of the material.
paul
   / Infrared Thermometer will it read a corrugated flue pipe #4
paul
Our engineers have us change the emissivity to .35 for the switchyards which are aluminum against the sky...
   / Infrared Thermometer will it read a corrugated flue pipe #5
I agree, but most simple hand held IR thermometers do not have the ability to set emissivity.
paul
   / Infrared Thermometer will it read a corrugated flue pipe #6
Mine can't read molten lead. Everything else it seems to do pretty good with. Just take a can of spray paint to the pipe and problem solved.
The flue pipe is back about 2 feet though a 1” slot in the masonry fireplace (see original posting picture) so painting it will be a challenge but I plan to figure out how.
   / Infrared Thermometer will it read a corrugated flue pipe #8
An artist brush on a stick.
   / Infrared Thermometer will it read a corrugated flue pipe #10
A can of marking paint would probably spray that far, but I don't know about the temperature rating. I'm not sure where to get high temperature liquid paint either. High temperature spray paint is easily accessible.
2019 Generac MLTS-1 2.4kW Towable LED Light Tower (A49461)
2019 Generac...
2011 GR TRAILER GOOSENECK (A50854)
2011 GR TRAILER...
Three Point Hitch Finish Mower (A48837)
Three Point Hitch...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
Pallet Fees (A50775)
Ford NAA Jubilee Tractor (A51039)
Ford NAA Jubilee...
