Information on Rockhound F-H Flail Shredder
   / Information on Rockhound F-H Flail Shredder
I've never used the FH, but comparing it to the 40EX Hammerhead is essentially a non start in accessible areas (Hammerhead is on the excavator). The Ground Shark is a beast of a mower, 4" material is essentially nothing. It's rated for 7" material, but that's conservative, based on my experience today. The blade carrier weighs 600lbs, carrying a huge amount of momentum into the cut to knock down larger material.
For knocking down what you described, it would be tough to beat.
"Non start" meaning the 40 EX can't compare to the Ground Shark? or the other way around?
I looked at the company video of the Shark and WOW!
I actually had problems with reference points on your pictures seeing how much you cleared in the 4 minute increment.(feet/distance)
   / Information on Rockhound F-H Flail Shredder #12
The ground shark is entirely more capable than Rockhound. In the 4 minute picture I took out the ~8-10" dbh gum. I cut the top out, mulched the trunk, then processed the top.
The first three pictures order is backwards.
Homemade Trailer (A50322)
Homemade Trailer...
Bobcat Skid Steer Forks (A50322)
Bobcat Skid Steer...
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A52128)
2016 Ford F550 4x4...
Quick Attach Pallet Forks (A47384)
Quick Attach...
2014 Ford E-350 Cargo Van (A50323)
2014 Ford E-350...
John Deere 1110 Field Cultivator - Heavy-Duty Soil Finisher for Precision Tillage (A52128)
John Deere 1110...
