information on 790 jd 4x4
   / information on 790 jd 4x4 #1
wayne spence
northeast,oklahoma
99' JohnDeere 790
broke four wheel drive shaft off in transmission,do i have 2 split tractor in half 2 fix? or is this a simple fix? this tractor was my father's who is now deceased, he loaned it out when he was alive, and the person broke shaft off in tranny houseing. any info is greatlly appreciated. thanks
   / information on 790 jd 4x4 #2
you are sure it's the transmission output shaft
for the drive shaft for the 4wd? not the
drive shaft itself?
if so, pretty sure it would require a split..
   / information on 790 jd 4x4 #3
drive shaft itself?
Yeah, a split and quite a few dollars...
You know, it really takes talent to screw up a 790.
   / information on 790 jd 4x4 #4
HE-HE talent:laughing: You funny Roy!!
Not heard of snapping 4wd shaft inside the tranny.... not that it cannot be done:eek:
I would verify, for sure, where the loss of drive is at.
Its common to grind up the gears in the front axle spindles with HEAVY loads and no give in traction on a 790.....
Could it be a slip collar on the actual drive line from the tranny to the front axle mabe???
yeah,the shaft is out and the broke peice is still inside, snapped the shaft off where it goes in to tranny.
thanks for info, kinda thought myself. and yeah a lot of money!!!! thank's
Yes, It is the output shaft 4 the 4-wheel drive shaft, found out the feller was tryin to climb on the back of a car!!! pretty sad when your own 8 yearold son tell's off on u !!thanks 4 the feed back
   / information on 790 jd 4x4 #9
Thats good to know, I will avoid climbing the back of cars with mine.........
Well, are you comfortable split'n the tractor in half??
If ya got a extra bay in the garage or a shop with a nice flat concrete floor, could save yourself some dollars....
Ether way I am pretty sure its gunna have to be split mabe not, but my guess is yes.
LOL' I hear that. yes i have room in garage, guess we'll have 2 c. thanks..
2018 Doosan DL220-5 Articulated Wheel Loader (A53421)
2018 Doosan...
2023 WESSEX RMX500 LOT NUMBER 44 (A53084)
2023 WESSEX RMX500...
PALLET OF MILITARY STRAPS (A54757)
PALLET OF MILITARY...
2020 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A52377)
2020 Caterpillar...
Killbros 260 Seed Conveyor (A55301)
Killbros 260 Seed...
2025 JMR 36in Mini Skid Steer Bucket (A53421)
2025 JMR 36in Mini...
