info on mitsubishi 370 tractor
   / info on mitsubishi 370 tractor #1
yankee farmer
mitsubishi 370
Can any one tell me what oil filter to use. Also where is the filter located for the hydraulic system. Their is a diagram on the clutch side of the fender but where is the filter.According to the info that filter gets cleaned with kerosene. I just bought this tractor with a bush hog for $1550.
Any information wold be appreciated for a new member.
thank you
   / info on mitsubishi 370 tractor #3
Napa 1334 is the oil filter. The hydraulic filter is located on the left side, down under the rear wheel. The cover is oval shaped and is held on with two bolts. Hope this helps.:)
Thank you tree cutter
If you own a 370 beaver are you familiar with a bush hog if so I tried cutting 6 inch grass/weeds on number one range on the pto with the trans in second gear.Can I use pto two range in second gear. I have no info on the 48 inch cutter. It is not made any more. The reason I am asking two range on the pto the drive belt I smell rubber smell and the belt is tight. I know without seeing the cutter it is a hard answer
thank you....Al
   / info on mitsubishi 370 tractor #5
yankee,
i think you might have a bush hog confused with a finish mower. I do not own a bush hog but I do have a finish mower. The finish mower is 48" and the 3 blades are driven with a belt. I would recommend using 1st gear on the pto with your rpms at about 2000. The gear of the tractor should be selected based on terrian and the height (thickness) of the grass. Also, in my opion the belt should have some play in it, 1-2". Hope this helps.
UNUSED LANDHONOR LHR-RC920 CHAINS & BINDERS (A54757)
UNUSED LANDHONOR...
UNUSED DIGGIT HEAVY DUTY 20'X20' ALL-STEEL CARPORT (A54757)
UNUSED DIGGIT...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
2012 Cadilac SRX SUV (A53424)
2012 Cadilac SRX...
2024 CATERPILLAR 255 SKID STEER (A52705)
2024 CATERPILLAR...
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A55301)
Adams Load Out...
