Info on International Super 10' cutter
   / Info on International Super 10' cutter #1
Slippy
Ohio
Mahindra 6000 4wd; IH x2; NHTC40DSS; International 1086; JD 5115M
Info on International Super 10\' cutter
Anyone have any knowledge, experince with International Super 10' pull type cutter, or info on the general quality, deck design, durability, etc. of International rotary cutter products? How do they compare to KK, Howse, Bush Hog, Rhino, Woods, etc.? Prices?
   / Info on International Super 10' cutter #2
Re: Info on International Super 10\' cutter
Slippy, As you may be aware, I too have a Mahindra 6000 and got the 7 ft (twin tail wheel) HD International rotary cutter. I've cut about 35 acres with it so far and everyone that has seen it/myself included, seems to think for the money, its just like the Mahindra: a great bang for the buck! The body is built like a tank (7 footer weighs in at about 1350 lbs or so), and comes with a slip clutch. I paid $1675 delivered to my tractor. Note, I backed it over a few 2 inch sapplings and didn't hardly hear anything but a couple of small "whumps"/machine didn't even vibrate as it chewed. My dealer (same as Mahindra) has been in the business for a long time and he says International is the way to go. I think he was right. Of course, your mileage may vary, but since you already have the best bang for the buck in your ride, I don't think you can go wrong with this either. BobG in VA
Bob: Do you know if your seven footer comes in different grades such as light, medium or heavey duty?
   / Info on International Super 10' cutter #4
Slippy, not sure about the others available from IM,except here is where you can view what Sweet Tractors has. My 7ft is hooked up to a Cat. 2, but I think it will also fit a Cat 1. I also note there is an 8ft that is only Cat 2. Good Luck!.
BobG in VA
http://www.sweettractors.com/new_equip_pg3.html
2025 K0311 UNUSED Galvalume Corrugated Steel Panel (A53117)
2025 K0311 UNUSED...
2012 CATERPILLAR 279C2 SKID STEER (A51242)
2012 CATERPILLAR...
2002 Enclosed Trailer (A52377)
2002 Enclosed...
2025 CFG Industrial MX20R (A50123)
2025 CFG...
2024 JOHN DEERE CP 770 LOT NUMBER 21 (A53084)
2024 JOHN DEERE CP...
2016 Mobility Ventures MV-1 Van (A51694)
2016 Mobility...
