Info. on B3030 50 hr service,
   / Info. on B3030 50 hr service, #1
cgreenway
Tennessee
09 Kubota B3030HSD-F
Well, I'm gettin close to my 50 hr service and was wondering what all I needed to change everything that is required at 50hrs ??, what kind of oil ( Kubota ,rotella,ect) and how much oil in the engine, which filters and ect. or if thiers a prior post on this service please direct me to it, I think I'm capable of tackling the task and would like to save a few dollars :), THANKS For any help,
   / Info. on B3030 50 hr service, #2
Here is a nice write-up on some of the things you'll be doing for the 50 hour service:
Kubota B-Series Fluids and Filters
Your owner's or service manual should list the fluid capacities. As I recall,
you'll change the engine oil and filter as well as the hydro fluid and the two hydro filters.
Vic
   / Info. on B3030 50 hr service, #3
Your Owners Manual should list the fluid capacities and types required, filter part numbers, etc...
You'll probably get a pile of responses telling you to use/not use this or that fluid/filter, but pretty much any name brand product out there will work fine as long as it meets the OEM specs. Nothing wrong with using OEM, although the cost is generally higher.
Take your time and you'll be fine. ;)
Or you could follow vic4's link - excellent write-up.
New Holland 451 Sickle Bar Mower (A50515)
New Holland 451...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
2002 International 4400 SBA 4x2 Flatbed Truck (A50323)
2002 International...
2011 TRAIL KING LOWBOY TRAILER (A50459)
2011 TRAIL KING...
2014 Gillig 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig 31+56...
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
