Info on a Ford 1920
/ Info on a Ford 1920 #1
bbse
Platinum Member
Nashville, TN
Mahindra 3325
I picked up a Ford model 1920 2WD w/o a loader. It is in pretty bad shape so I am going to spend some time fixing it up. One problem is all the turnbuckles are rusted and I broke one trying to loosen it up. I am hoping tractor supply has some. The engine starts smoothly and runs strong but there is a little smoke when you first start it. That may go away in time as it has been setting a long time. The hour gauge, fuel gauge and temp gauge all act like they are bad. There are holes in the fenders but fixable. Body isn't too bad and tires are decent. It came with the front weights, the seat is rusted in place so I am sitting too close to the steering wheel. I will have to install a sat belt as it is missing........that is it in general.
My main question is about the transmission. It looks like it has 3 forward ranges with a 4 speed tranny, with 1 reverse range. The indicator panel is on the dash is gone so I was wondering if someone here could give me the skinny on the shift pattern. It looks like low range is lower left, reverse is lower right, mid range is upper right and high is upper left.....but I was getting some speed out of mid range so I wasn't sure that was correct....also there does not seem to be a separate lever for shuttle, is that correct?
/ Info on a Ford 1920 #2
is it not the 4 range 3spd+R column shifter ?
soundguy
It is a 3 range/ 4 speed. The dash plate is mostly gone so I just wanted to be sure. The other thing I wanted to know was if the tranny was synchronized for the reverser, I know I have to clutch. I think the 1-4th is synchro too but the ranges are not....is this correct.
/ Info on a Ford 1920 #4
hmm..
my 1920 was a 4 range, 3 speed+R making 12f/4r I've seen 12/12 trannies.. but not anything that would be 12/3
is your range selector on the left lower side of the seat? and a column shifter at the steering wheel?
/ Info on a Ford 1920 #5
just re=read your message. sounds like you DO have the 12x12
soundguy
Yes, I have a 4 speed shifter on the left side by the seat and a 3 speed range selector w/R on the left side of the dash. So it would be a 12 forward and 4 reverse. What I was surprised at is how close together the the gear ratios are.
[/URL] Uploaded with ImageShack.us[/IMG]
What it looks like is the they are spacing the gears based on the dash ranger, not the gear shifter.....which one is synchronized? The dash or the other?
/ Info on a Ford 1920 #7
what you are calling a range selector onthe dash is the gear shifter itself.
the 'range' selector is the 4 way on the left side...
OK, so the shifter is synchronize? I am going to drive it later today as it is finally drying out.....it was just too wet, we had some gully washers come thru here Friday.
/ Info on a Ford 1920 #9
I don't think anything is syncronized on this tranny. You may find you can slip gears a little with the dash shifter, but the range selector (on the fender) will be even less forgiving.
/ Info on a Ford 1920 #10
i agree.. I was never to do any shifting on the fly on my 12x4 :)
Had her out today and finally got it sorted out. That is strange that they would give you 4 ranges with 3 speeds. I found in the flat parts of my field I could cut in 3rd range/ 2nd gear......or should I call it 3rd gear mid range. I could drop it to low or reverse with no problem using the dash shifter.
Smokes a little when you first start it. But it starts right up and runs strong so i figure it is from setting so long. It hasn't really been run much in a couple of years. I need to check that air filter too.
I also have to add water to the rear tires. I can go up the hills OK but I slide down the them. I also have to add a seat belt as it is missing. It is going to be a fun project.
Thanks for the help
/ Info on a Ford 1920 #12
Does it have a rops? If not, I don't think it's supposed to have a seatbelt. Chime in, please.:)
Oh yeah...it has a rops
/ Info on a Ford 1920 #14
a lil smoke at startup is normal. if it has been babied it may slobber or wet stack some.. try running her good and hard.. smoke may simly clear up. a lil fuel cleaner won't hurt either..
Excavator Tooth Bucket (A62177)
Excavator Tooth...
LandHonor LHR-MS0608 Galvanized Apex Roof Metal Shed (A60352)
LandHonor...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A58216)
2014 MAGNUM...
2025 Unused SDLGC80 Electric Golf Cart (A60352)
2025 Unused...
Brock 48'x16' Flat Bottom Grain Storage Tank (A57148)
Brock 48'x16' Flat...
