Info on 1430
   / Info on 1430 #1
Highridge
Southeast, MA
Power-Trac 1430 and Craftsman DGT6000
Hi,
I've been learning about Power-Tracs for a few months and they seem like great machines. The video only made it look nicer!
I think the tractor for me is the 1430. I only own 3 acres right now, but will be purchasing 12 acres soon. Right now I own a Craftsman GT with a Johnny Bucket and well, I tried /forums/images/graemlins/smile.gif
Now I'm ready for the real deal.
I was wondering what you 1430 owners think of your PT's.
   / Info on 1430
Well, I plan on getting the 9 cu. ft bucket, mini-hoe, and stump grinder. I have some woods to clear out so later I would buy the grapple bucket. I also like the 60" snowblower - I would probably get that before next winter too.
The land that I'm clearing is half swamp/half woods. There is a trail going through it and I'll being adding gravel to that. I think the 9" ground clearance is perfect since the underside of the PT is all steel /forums/images/graemlins/smile.gif
   / Info on 1430
Also, how about the Deutz Diesel Engine?
How is it on fuel consumption and starting?
How does it compare to the 3 cyl. deisels in the larger PT's?
   / Info on 1430 #5
In this thread, somewhere around the middle, there are pictures of the 1430 and 425 side by side.
Click here for link
(If you are considering the 425 at all, it's a good comparison)
EDIT: Shortened the link.
   / Info on 1430
Yes, I've seen those pictures(good pictures, by the way)
The 1430 is wider, better on slopes. I don't have any significant slopes but the extra stability is good.
   / Info on 1430 #7
If your planning on getting the grapple bucket than I wouldn't bother with the 9 cu. ft. bucket. The 18 cu.ft. light material bucket will be much more usefull. The grapple bucket can be used for heavy digging like the small bucket. I'm just over the line in Northwestern CT. so if your in Western Mass., your not to far from me. I'd be happy to let you check out my 1430 and attachments.
   / Info on 1430
RegL,
Thanks!
I'm in Southeast Mass, so I'll think about it.
Can you use the Grapple as a normal bucket without taking the grapple part off?
   / Info on 1430 #9
</font><font color="blue" class="small">(
)</font>
Yes you can, But if you get the large bucket, you probably never will.
   / Info on 1430 #10
I have had a 1430 since 1999 and I have been very pleased with it. I have 10 acres of hilly, heavily wood land. The 1430 has done everything that I have asked of it. I use it primarily for clearing tees, landscaping, filling in gulleys, grinding stumps, grading my driveway, clearing snow, clearing underbrush, cleaning flower beds, cutting trails, moving dirt, hauling mulch, digging up shubbery, etc. In addition, we have a lot of very large rocks. I'm amazed at the size of rocks that I have moved around with the 1430.
I have had very few problems since I purchased the 1430. Trash in the fuel tank was fixed in about 15 minutes. Broken bolt on the foot pedal, worn fan belt, burned out light bulb. Simple things that are easily fixed. I have seen no need to make any modifications. I have the bar tread tires and would recommend them particularly if you have any creeks or muddy areas. I have never been stuck and have used it for pulling out my truck numerous times. The tractor is easy to work on. I tried finding filters, etc., locally but found that I could get them easily from Power Trac. I always perform the maintenance as recommended by Power Trac.
It always starts regardless of the temperature. It is easy to work on. I am impressed with the manufacturer and his response for delivering parts when needed. I have had the tractor in some pretty precarious situations and have had no fear of it turning over which is the main reason that I selected this tractor. Many of the problems that I have read about with the other tractors, I have not experienced.
This tractor is perfect for me. Once I became familiar with its operation, I was really impressed with how I could simply push over trees and the put the bucket under the roots that were exposed and just pop them out of the ground. I find that the roll over protection is indispensible, particularly when dead limbs are in the trees you are pushing over. The articulation allows you to get into places that you could not with a normal tractor or skidsteer.
In the future, I intend to purchase a rough cut mower, finish mower, grapple attachment for my bucket, and mini-hoe. I frequently use all of the attachments that I have purchased and now find that they all are a necessity for me particularly the adjustable forks.
When I originally went to Tazwell to purchase the tractor, I was really interested in the 425; however, after driving the 425, I realized that there was not sufficient room for my feet when operating. After driving the 1430, I was sold on it. There was much more room, it had a high lift height and would lift more weight. The spec. say that it will lift 1200 lbs., but I believe that it lifts more.
This tractor really doesn't belong to me. It is my wife's. Make sure you take her with you when you purchase it. There are a lot of advantages to this arrangement. I can buy attachments as gifts for her. Smart, huh?
/forums/images/graemlins/grin.gif
2013 John Deere Gator 825E (A51573)
2013 John Deere...
2013 KENWORTH T370 DUMP TRUCK (A51406)
2013 KENWORTH T370...
2024 JOHN DEERE 8R 280 LOT NUMBER 7 (A53084)
2024 JOHN DEERE 8R...
2016 INTERNATIONAL MA025 BOX TRUCK (A52576)
2016 INTERNATIONAL...
Clark G500-50 4450lbs Propane Forklift (A51691)
Clark G500-50...
2013 ISUZU NRR 20FT FLATBED TRUCK (A52576)
2013 ISUZU NRR...
