Info about hydraulic fittings
   / Info about hydraulic fittings #1
terraformer
N.E. Mo
Mahindra 3510, Bolens G192/Iseki 1910
I am looking for info on hydraulic connectors for Mahindra ML112 hydraulic system and am cross posting it here.
Looking to ID the proper termination
Here is a picture.
https://www.tractorbynet.com/forums...ting/423774-mahindra-ml112-hose-question.html
thanks
   / Info about hydraulic fittings #2
The one on the left is a Straight Thread O-Ring Boss type of fitting, the other appears to be a swivel flare. Take the assembly to your local Parker Fluid Power branch and they can identify it for you and get you fixed right up.
   / Info about hydraulic fittings #3
Hi if I was not social distancing I would have taken the part in for sizing and had the part in a jiffy
Read the ID book and noticed that my my thread was either 14x1.5 or 9/16x18. Ever try to measure the difference in them with a calipers. They are essentially the same but not as you know.
   / Info about hydraulic fittings #5
Yes metric vs SAE is confusing especially on fittings with very similar profile.
Usually threads per inch is the best indicator but not fool proof. some companies have a thread gauge to assist in thread identification
   / Info about hydraulic fittings #6
Not having your hose in my hand I would say that mcfarmall has the correct answer on the o-ring fitting,
not seeing the inside of the female swivel my first inclination would be JIC.
   / Info about hydraulic fittings #7
Yeah they are close, but (for external threads, at least it can be done with a digital caliper (and usually a calculator) - the way I do it is to use the inside (pointy) ends of the caliper - get in front of a light colored background, use as many threads as are available, measure either from peak to peak or trough to trough of the threads, divide that length by the # of threads you measured; it's easier if your caliper allows switching between inch, fraction and mm.
Example - if you're lucky enough to have a full ten threads showing, you can just measure that and divide by 10. If they're metric, you should be done. If inch, obviously you would (in your example) have exactly 9 threads in .500".
I have a slight advantage in this method, I'm so nearsighted I actually have BETTER than 20/20, up to about 9 inches :rolleyes:
With your female end, it'll probably easier to look at the male it came off of (if it's even accessible)
Your avatar - I haven't seen the "Lightning-Fast Chicken F'r patch in about 50 years :laughing: (Ft. Devens, 1966-68) ... Steve
Actually there are only about 4 threads that I can reach with the calipers. I got 1.46mm So is it 1.50 or 1.41 mm? In a world called perfect the thread would have a sharp edge. but it doesn't. I will check the end that is sticking out of the hard line.
It is one of these I feel.
Steve, I am working at about 5" and spent my entire career measuring optics. Worked in a metric based system but my use both systems. Quite a switch from being a 33d back in Devens in 70-71 and korea after.
Dave
   / Info about hydraulic fittings #9
What I do quite often with the straight thread fittings is go stand at my bolt bin and check them with bolts and nuts both SAE and metric
   / Info about hydraulic fittings #10
The left one looks like a MB fitting.....look for numbers on it.
MB = Male Boss; threaded fitting with an O-ring seal. MB is also
called SAE Strait Thread or “-AN”.
The other looks like a JIC
2008 CATERPILLAR 304C CR EXCAVATOR (A51406)
2008 CATERPILLAR...
2025 CFG Industrial MX50R (A50123)
2025 CFG...
UNUSED FUTURE FT-P45 HYD BREAKER HAMMER (A51248)
UNUSED FUTURE...
UNUSED WOLVERINE BC-13-72W-72" HYD BRUSH CUTTER (A51248)
UNUSED WOLVERINE...
2007 FORD F-550 XL SUPER DUTY DUMP TRUCK (A51406)
2007 FORD F-550 XL...
2010 Chevrolet Malibu LTZ Sedan (A51694)
2010 Chevrolet...
