INEXPENSIVE REMOTE HYDRAULIC VALVE?
   / INEXPENSIVE REMOTE HYDRAULIC VALVE? #1
JRP
Platinum Member
South Texas
Kubota M6800
My dealer gave me a price of $700 for a second remote valve for my M6800. This seems like a lot for a valve, two hoses, and two couplers. Has anyone looked real close at a "kubota" remote hydraulic vale to see if it is actually another brend?
I could see Kubota buying a Prince valve or something for $100 and marking it up. Perhaps I could buy only the fancy bent lever from Kubota.
   / INEXPENSIVE REMOTE HYDRAULIC VALVE? #2
Maybe I'm showing my ignorance here, in that remotes would be that different than the loader controls, but the loaders (gotta learn to say FEL /w3tcompact/icons/eyes.gif) I've seen lately have HUSCO valves. Somebody enlighten me, too
So bota loaders use Husco valves, right? That is a start. My service manual shows very good drawings of the remote valves.
   / INEXPENSIVE REMOTE HYDRAULIC VALVE? #4
Kubota does use Husco valves for FEL's. Don't bother contacting Husco. They will give you no info and are rude to boot. I went thru this about 1 1/2 years ago. I asked Husco for a schematic for my valve and you would have thought I asked for the Moon.
   / INEXPENSIVE REMOTE HYDRAULIC VALVE? #5
McCallum, I did the same thing with the same results a couple of years ago./w3tcompact/icons/frown.gif Husco folks don't even want to hear from you or talk to you.
   / INEXPENSIVE REMOTE HYDRAULIC VALVE? #6
I looked a bit when I bought for my TnT. Basically, I found the cheaper the valve, the bigger it was. I ordered a Prince 3-sp from Northern for $189. It reminded me of Fred Flinstone at the drive in when the car-hop set the rack of ribs on his car and it flipped. For my little B8200, the valve was twice as big as the fender. I wound up with a Tisco 2-sp valve for about $225 that fit better.
2018 Atlas Copco Pas200HF water pump powered by Duetz diesel engine with Bin Pump (A52377)
2018 Atlas Copco...
2003 GROVE TMS500E MOBILE TRUCK CRANE (A51406)
2003 GROVE TMS500E...
UNUSED Under Mount Stainless Steel Sink & Faucet (A53117)
UNUSED Under Mount...
2025 IR UNUSED Hydraulic Thumb (A53117)
2025 IR UNUSED...
2019 CATERPILLAR D6K2 LGP CRAWLER DOZER (A52706)
2019 CATERPILLAR...
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
