Tires industrial tires need replaced
   / industrial tires need replaced #11
I got the tire replaced yesterday It was only 145 $ so i ordered another one to have to matching tires They are different brands ( i don't really care ) but a different tread pattern and the other one is tore up pretty good . I had just ordered 2 new front tires for my old Cockshutt and they were 95$ apiece so iwas expecting to pay a lot more for the bigger wider Kioti tires You just never know .
Because of the tire size stamped on the side of different tire brands are matching, it does not necessarily mean that the tires are the same size at all in actual dimension. I know when I ordered my rears, there was a little bit over an inch in tire height difference between the exact same labeled tires from different manufacturers. Its tire height that comes into play here rather than anything else such as tread design.
The new tire is a different style of tread more aggressive .Also being 4 wheel drive I ordered a second one to keep everything the same The other tire is worn down I can really see a difference when compared to the new one I realize now i just should have bite the bullet and replaced both tires at the same time
2009 Haybuster GP-50 Grain Processer (A55315)
2009 Haybuster...
Electric Horseless Carriage (A57453)
Electric Horseless...
2020 International MV607 26ft Reefer Box Truck (A56858)
2020 International...
2008 SPM 2500HP QUINTUPLEX FRAC PUMP (A58214)
2008 SPM 2500HP...
2019 Deere 550K (A53317)
2019 Deere 550K...
2017 Ford F-350XL (A57148)
2017 Ford F-350XL...
