Indirect Hot water tank
   / Indirect Hot water tank #1
dlabrie
Campton, NH
Kubota B2910
I am having an outdoor wood furnace installed. It will run a HW loop to my existing FHW system, keeping it up to temp. I want to run a zone to a DHW storage tank. The installer can get a Vaughn 35 gallon, stone lined, system for $800. Home Depot has an Amtrol 41 gallon, DH7P series, system with a circulator for $819. The installer said he would install either, but wouldn't warranty the Amtrol. The Vaughn comes with a 5 year warranty and we would use an existing Taco circulator. The Amtrol, Boilermate comes with a lifetime warranty and its own circulator.
Has anyone had any experience with the Amtrol Boilermate or the Vaughn systems?
Thanks,
   / Indirect Hot water tank #2
We have a Boilermate that we are putting in my house. Have hooked the zone up to but have not wired it in yet but it is a fairly simple project. I do not know anyone around here that has one and I don't think our plumbing supplier sells too many of them as they did not know how to answer a lot of questions we had before we bought ours. They are a big outfit with 3-4 stores in WNY and are know their stuff. So we kind of knew we were taking a chance on the boilermate when they did not know much about it other then reading the literature. But if it performs like they say then we are going to like it.
My problem with your install is this, you have an outdoor furnace so you need to put wood in it to run. Why run a hot water tank of this system? You will have to keep wood in that furnace year round to keep hot water. If you had a gas boiler then it is a different story. The boilermate is supposed to help the gas boilers longevity by keeping it running year round instead of shutting down for long periods of time. It is suppose to be more efficient also as we have a 96% efficient boiler and most gas hot water tanks are no where near that and the ones that do come close cost a lot and don't have a lifetime warranty.
   / Indirect Hot water tank #3
I have indirect hot water heating. All I can say is,.. what's to warrantee? A tank, some pipe,..ok so there's a circulator. If they put in a B&G (which I would insist on) you'll have no problems for well over 5 years. If they put in a little ceramic job, I dunno.
Hot water off a wood stove sounds iffy to me as well... but that's not what you asked. Go with the cheap one. And get a big big tank. Recovery is slower than you think.
   / Indirect Hot water tank #4
I heat my DHW with my outdoor wood burner.
First question. Why would you get some special tank for your DHW??
I have a 80 gal electric hot water tank, GE, bought it at Lowes for around 275, and a 4x8 inch heat exchanger. I heat with the wood in the winter and use the electric in the summer. Its a matter of shutting the mixing valve and cutting in the breaker. There are no circulation pumps for the DWH, the heat exchanger is outside the HWT and convection current moves the water. Recovery doesnt take any longer on the wood burner than the electric. It seems shorter in fact, probably because the water from the burner is 180-190 at all times.
Re: Indirect Hot water tank
<font color="blue"> </font><font color="blue" class="small">( ( DHW? ) </font>)</font>
Domestic Hot Water
<font color="blue"> </font><font color="blue" class="small">( ( Why run a hot water tank of this system ) </font>)</font>
<font color="blue"> </font><font color="blue" class="small">( ( First question. Why would you get some special tank for your DHW??) </font>)</font>
I have an oil, FHW system in the house. I currently get my hot water from a DHW coil in this system. I could just use the Wood furnace to circulate the 185 degree water through my oil system and be done with it. However the coil is old and should be replaced and the oil furnace is 32 years old and not very efficient. When I replace it in the future, I will install a boiler without a domestic coil and use theBoilermate
that I plan to install now. If I already had an electric water heater, I would just use a heat exchanger and a tempering valve to keep the DHW up to temp. The boilermates are supposed to be very efficient at keeping water hot.
I currently have an indoor wood boiler linked to my oil system, but that too is 32 years old and not very efficient. So I am taking it out of the house and replacing it with a
Central Boiler
Wood Furnace. This will put the mess and fire hazard 100 feet away from my house. The furnace holds 350 gallons of water and will be linked to my oil system via insulated, underground lines. The wood furnace can be set to maintain the water at whatever temp. you set it at . The circulator at the wood furnace will circulate continuously to keep the oil furnace at temp. The house has 3 zones and will call for heat as needed. A 4th, priority zone will be set up for the boiler mate. The Boilermate has an aquastat with a digital readout. You can set your DHW temp with the push of a button. Once the system is together, I plan to shut off the oil furnace, and just use wood. I cut my own wood for free so I will only use oil if I go away and turn the furnace back on. I will also have a way to unplug the system from the electric grid and plug the system into my generator as a backup.
Folks that I know with a similar setup, load the stove twice a day in the coldest temps,around -20, once a day when the temp is around freezing and once every 3 days in the summer to keep the DHW hot.
   / Indirect Hot water tank #7
Or you could look at the Central Boiler dual fuel units. And the Hydrofire by Central Boiler Stainless Steel. www.hydro-fire.com
I have one and am coming from a position of been there. I was not blowing sunshine when I asked the question. /forums/images/graemlins/grin.gif
Mine is a dual fuel Hydrofire, wood over oil. I have 3 zones and the heat exchanger for the DHW. 2 in the concrete floor, radient heat, 1 forced hot air for the upstairs, wanted ductwork for AC if I want it later.
The furnace heats to 190 and the damper shuts, it opens at 180 and burns to 190. In the dual fuel it will stay open until the water temp gets to 152 then the damper shuts and the fuel oil will keep the temp between 152 and 160.
You control the temp by the thermostat which will send hot water through your system until it reaches X temp. You do not control the temp of the furnace. Just your zones.
Your neighbors are exactly right on line with the burn times I have had. Real cold (0 +-), 2 times a day 40-50 once every day and a half. The warmer it is the less you fill it.
If you are going to replace the oil burner anyway, you might want to think about a dual fuel unit. It is real nice to start the fire also. Put wood in, close door, turn to oil backup, turn power on, walk away. I like that in a woodburner /forums/images/graemlins/grin.gif so does the wife.
   / Indirect Hot water tank #8
We install a lot of the Boiler Mates. Have had no problems with any of them yet. My house has one of the competitors and no problems with it either. There really isn't much that can go wrong with them. 40 gals unless you are using it totally for storage is a bit small. Typically in houses such as mine we use the 80 gal. Found some houses where even the 60 won't keep up with a whirlpool type tub.
murph
Murph,
Now you have me worried. The installer and others I have talked to said I would have more DHW than I could ever use.
Our usage consists of showers, dishwasher and washing machine. I thought I had it all figured out, now, I am not sure.
Varmintmist,
I thought about the dual fuel option, It really looks like a great Idea but I like the idea of having a separate oil unit in the house, in case something goes wrong with the outdoor furnace. Also for resale value, some folks don't want to be bothered by wood and I feel you loose efficiency mixing the 2 together.
   / Indirect Hot water tank #10
David,
OK, we have a natural gas fired hot water baseboard system, with an indirect hot water tank. I don't remember the brand, and the tank is no more than 40 gallons. The week it was installed I was taking a shower, but I didn't realize my wife had started washing clothes. Meanwhile she started the dishwasher. I never noticed a temperature change even though the pressure was down a bit. I'm quite sure that we can run the well dry before we will run out of hot water.
BTW yes, My wife can be a bit wicked, and I think she did that on purpose, but I love her anyway. /forums/images/graemlins/grin.gif
Mike
2019 Chevrolet Tahoe SUV (A50324)
2019 Chevrolet...
Kubota KX057-5 (A50120)
Kubota KX057-5...
toro turf sweeper (A50324)
toro turf sweeper...
Maletti BCV3180 (A50121)
Maletti BCV3180...
(2) Flower Pots (A50121)
(2) Flower Pots...
2013 Chevrolet Cruze LS Sedan (A50324)
2013 Chevrolet...
