Indicator Bulbs
   / Indicator Bulbs #1
jebb
Central Kentucky
Kioti DK35
I have a turn signal indicator bulb and a 4WD indicator bulb on the dash that have burnt out. Does anyone know the proper replacement bulb. I would like to purchase the replacement prior to taking the dash apart.
   / Indicator Bulbs
I guess I should have said that I have a DK35
   / Indicator Bulbs #3
My dash illumination lamps are 3.4 watt wedge base. I know this as they are sitting at my compuerter desk. I would assume they used the same lamps throughout the dash but this lamp is off a LB1915
   / Indicator Bulbs #4
Along these same lines, I have a new ck 30 and some work and some do not. My parking brake both turn signals oil and igniter work. How many more are supposed to work in a gear model? Do I hav a 4x4 light? pto light? high range? low range? any other? Thanks, Mike
   / Indicator Bulbs
Thanks so much for your help.
2013 VERMEER RTX1250 RIDE ON TRACTOR (A51242)
2013 VERMEER...
BUNDLE OF USED GALVANIZED CORRUGATED METAL SHEETS (A51244)
BUNDLE OF USED...
UNUSED AGT MCMRT14 STAND ON SKID STEER (A51243)
UNUSED AGT MCMRT14...
Miller Welder (A51691)
2005 Pierce Enforcer Special Operations Fire Truck (A50323)
2005 Pierce...
UNUSED JCT SKID STEER QUCK ATTACH 72" BRUSH CUTTER (A51244)
UNUSED JCT SKID...
