Hi,
I am hoping someone will be able to answer what seems a simple question.
As you may be aware I have a compact tractor (MF) with an independent PTO, I can flick the switch in the cab to turn it on and select what speed to run at.
The question I have is when idle and setting the speed is it then running at that speed or is it reliant on the engine speed to get up to the 540 etc?
Thanks,
Kevin
Thanks,
Kevin
