Independent PTO Not so Independent...
   / Independent PTO Not so Independent... #1
Bamaram
North Alabama
Ford 4000
1968 Ford 4000 3cyl Gas
When I start her up the PTO is turning regardless of what position I have the lever. If I have the PTO disengaged and don't have the bush hog hooked up the PTO seems to turn the same speed as when the PTO is engaged. If I hook up the bush hog the PTO barely turns the blades until I engage the lever. When I engage the PTO everything is smooth and the bush hog runs great. I know the independent PTO works off a set of clutches/brake that stops the PTO from turning when not engaged. My question is, will it hurt anything further to just leave it be? How hard is the replacement of those clutches/brakes?
I always forget to put that in my posts. It is the 8X2 transmission.
   / Independent PTO Not so Independent... #4
if the pto will spin a mower over when not engaged.. that's a lil more than the common worn brake and oil coupling.. almost sounds like warped discs in the clutchpack.
I'm not really a 3 cyl guy.. so see what rickb has to say.
soundguy
   / Independent PTO Not so Independent... #5
Probably just a worn brake pawl if it spins the RC under no load. Now if it wanted to cut grass when the lever is in the 'off' position, that's different.
   / Independent PTO Not so Independent... #6
This sounds like a live pto with a clutch rather than an independent pto.:confused2:
larry
   / Independent PTO Not so Independent... #7
larry
Not on a 1968 Ford 4000. Fully independent multiple disc wet clutch, hydraulic control. SOS and 8X2 have different clutchpacks and the SOS version has no brake.
   / Independent PTO Not so Independent... #8
Then it is out of gear when disengaged as is usual w/independent? The description seemed to indicate that there was real torque output beyond oil drag when the pto was disengaged. Im not sure how that fits. My ptos can be restrained with fingertips when disengaged if they even turn at all.
larry
   / Independent PTO Not so Independent... #9
larry
Larry,
The tractor has independent PTO. I'm pretty certain that you and I both know what that means.
A 4000 with a failed PTO brake pawl would probably cause you some harm if you grabbed the shaft and tried to stop it.
TO the OP:
A rear split is required in order to replace the brake pawl. Further damage to the mechanical parts of the tractor is unlikely if you don't fix it. But it is a safety hazard.
   / Independent PTO Not so Independent... #10
I take it youre saying that a pto having gears meshed from the engine through the trans to the output stub is independent if there is an independent clutch somewhere in the string. All the independents I have do not have gears meshed and require operating the pto clutch to mesh them and then ultimately to power the stub. My thot is that while the 1st may act independent enuf to be called that, it is actually a live pto with an internal clutch that is disengaged. :confused2: Doesnt that analogy fit? ... I think that design is inherently dangerous when the engine is running.
larry
2000 Cummins DGDB 100kW Standby Diesel Generator (A56857)
2000 Cummins DGDB...
2006 Chevrolet Express 3500 Versalift Vantel29N 29ft Bucket Van (A56858)
2006 Chevrolet...
Case Titan 3530 (A56435)
Case Titan 3530...
2015 Kenworth T880 QMC 8060R 40 Ton Tri Axle Crane Truck (A55973)
2015 Kenworth T880...
6' STAINLESS STEEL TABLE (A58374)
6' STAINLESS STEEL...
2012 TEX MEX TRAILER LOW BOY GOOSENECK (A58214)
2012 TEX MEX...
