Independent lift for a 72" mid moutn mower on a 2013 4320
   / Independent lift for a 72" mid moutn mower on a 2013 4320 #1
dncree
SW PA
JD 4320
Does anyone have an independent lift for a 72" mid mount mower on a 4320? I have a 2013 4320 with a 485 backhoe. I would like to be able to drop the backhoe and use the mower without removing the sub frame. JD Parts shows an independent lift, LVB 25630, but it only consists of a single cylinder and hydraulic hose with fittings.
   / Independent lift for a 72" mid moutn mower on a 2013 4320 #2
Can only speak to 3x20 series, but yes the hydraulic lift consists of a single cylinder, with lift arms, with two hoses that attach to the 3rd SCV. Also required are a number of brackets / arms to attach the MMM to the tractor. At least one bracket is different depending on CAB / OS. If just plain lazy or not worried about weight the BH can stay mounted with the MMM, since the BH operates with the Power Beyond valve. Check parts / dealer for all the bracket #'s
If you don't have MMM check this thread - for sale. http://www.tractorbynet.com/forums/john-deere-owning-operating/306020-whats-72-mmm-mower-worth.html
Thanks for responding. I traded a 3520 cab on the 4320 o/s. I had the independent lift on the 3520. The underside of the 4320 doesn't look anything like the 3520. I have the hydraulics for an independent lift on the 4320 but I'm trying to figure out what I need on the linkage side.
2009 Pierce 105ft. Ladder T/A Fire Truck (A53422)
2009 Pierce 105ft...
JOHN DEERE BACKHOE FORK ATTACHMENT (A53843)
JOHN DEERE BACKHOE...
BACKHOE BUCKET (A53843)
BACKHOE BUCKET...
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB Crane Mechanics Truck (A52377)
2015 Ford F-350...
Toro Workman Low Profile Spray system 175 (A50322)
Toro Workman Low...
2018 Skyjack SJIII4740 40ft Scissor Lift (A52377)
2018 Skyjack...
