Increasing lift capacity 3pt hitch of Kubota B3200
   / Increasing lift capacity 3pt hitch of Kubota B3200
I think I managed ;-)
Oeps...and a picture of my daughter...:confused:
   / Increasing lift capacity 3pt hitch of Kubota B3200 #34
What pressure does the gauge read now that you have shimmed the relief valve?
Aaron Z
   / Increasing lift capacity 3pt hitch of Kubota B3200 #35
If your tractor has a loader or remote valve, you need to set all the valves the same, as the lowest relief valve upstream will do all the relieving.
You also need to stay within the tractor psi specs or you take your chances.
Say your loader relief is set to 2650 pso. and you set your 3pt relief to 3000. Guess which relief valve will relieve if you overload the 3pt.
The loader valve will set your limits in this case.
Hello,
Thanks for your prompt replies. My problem however is that only can find one relief valve and that's the one below on the right side. See picture (the bolt closest to the white filter, half behind the tube). Does anybody know where I can find the second relief valve on my B3200??
   / Increasing lift capacity 3pt hitch of Kubota B3200 #37
If you don't have a loader or remote valves, you only have one on the 3pt area.
Your question has been answered in several post.
I have also a FEL but maybe the 3PT and the FEL work on the same relief valve?
   / Increasing lift capacity 3pt hitch of Kubota B3200 #39
Give us the loader model number. All the numbers.
Your loader is a LA504 and it has a relief valve.
The flow goes through the loader first and then the 3pt.
So you have to bump up the loader relief and the 3pt if you want more lift, at your risk.
Do you really have a B3209, or should it be a B3200
I have a B3200 and a LA504.
The questions stays where do I find the second relief valve
Food Truck - 1999 Chevrolet Blue Bird School Bus and Turnkey Food Truck Business Package (A53472)
Food Truck - 1999...
2023 LMC M40018 LOT IDENTIFIER 163 (A53084)
2023 LMC M40018...
UNUSED AGT QUICK ATTACH AUGER SET (A51248)
UNUSED AGT QUICK...
PumpJack Brand Pump Jack (A53472)
PumpJack Brand...
2021 Bell TC-11A Crawler Carrier Dump (A52384)
2021 Bell TC-11A...
UNUSED GOLD MOUNTAIN M122009 12'X20' STEEL CARPORT (A51248)
UNUSED GOLD...
