increasing gpm in a 790
   / increasing gpm in a 790 #1
sean miller
new hampshire
how would one increase their gpm flow in a 790 john deere i installed a pressure guage in the hydraulics and shimmed it on the relieve valve.i do have a considerable amount of counter weight and having the cylinders enlarged would allow for more volume but also slow down the system any thoughts would be appreciated
   / increasing gpm in a 790 #2
You would have to replace the pump with a bigger one, and it's just not feasible to do that.
   / increasing gpm in a 790 #3
Sean, why do you think you need more GPM?
I agree with Kenny...probably not feasible, but with enough $$$, I'm sure it could be done.
But the 790 is a pretty light tractor (about 2000 lb ± 200 lbs). Increasing GPM would result in better FEL performance, but you may overstress the rest of the tractor so you may want to consider a 3xxx series machine.
The 790 is a value tractor and very good at what it was designed to do...but that means working within it's capabilities.
   / increasing gpm in a 790 #4
Depending on what you are looking to do, you could add a PTO pump?
2017 JEEP PATRIOT (A51406)
2017 JEEP PATRIOT...
Mission 6" Centrifugal Pump (A50121)
Mission 6"...
2016 FORD F-250 PICKUP TRUCK (A52576)
2016 FORD F-250...
Power Unit (A50121)
Power Unit (A50121)
Greenworks Commercial 82V CZ60R Zero-Turn Mower- BRAND NEW, NEVER USED (A52748)
Greenworks...
New Holland B95 Backhoe (A50490)
New Holland B95...
