Increasing capacity of a trailer
   / Increasing capacity of a trailer #1
oleman
I want to increase the carrying capacity of my tractor hauler.
This is a factory made 16' car hauler trailer. I added 600 more pounds of steel too it that significantly increases the frame structure.
Currently it has 2 EA 3500# axles, with electric braking on the rear axle only.
I can install another 3500# el braking axle for a 3 axle setup at 3500# each which will spread the load over more of the frame and make it a more stable hauler except on tight turns.
This mod would give it 10500 capacity on the ground with 2 axles braking.
The advantage of another 3500 is all the wheels and tires and brakes will be the same.
I could change out one of the 3500 axles for a 5000 braking axle, giving it 8000# at the wheel.
OR add a 5000# axle with braking making it 3 axles with 12000 at the ground.
The 3500 and 5000 axles are essentially the same dimensions and would be an easy fit.
A more costly option would be 2 new 5000#/ 7500 axles with brakes.
My currently thinking to get the 10,000 gross I want is 3 ea 3500# axles.
The cheap way out.
Any trailer modification experts out there?
This is in Texas registered as a farm trailer, legally it can be any thing I want it to be.
   / Increasing capacity of a trailer #2
Can you get away with 4 axles @ 3500# ea would give you 14,000lbs minus the empty weight of the trailer would give you a payload of 10,000# +/-
I just found this, does it apply to you?
Trailers with a gross weight exceeding 4,500 lbs. must pass an annual safety inspection.
https://txdmv.gov/motorists/buying-or-selling-a-vehicle/trailers
Another thought. IF you increase the capacity of your trailer, will you need to get it inspected for the increased weight? As well as the annual safety?
   / Increasing capacity of a trailer #3
I would hope its gross weight does not exceed 4000 lbs its a 7000 lb 16' car hauler not much good if it can only haul 2500 lbs what car would it haul?
   / Increasing capacity of a trailer #4
Some states require all trailers above a certain weight to have brakes on all axles.
If you have a 5000lb axle and a 3500lb axle, how will you arrange to have the 5000lb axle carry more weight?
I would go with two 5000lb axles and sell the old axles on CL to recover part of the cost.
Bruce
   / Increasing capacity of a trailer #5
I would sell it and buy a heavier duty trailer but since you have already added the steel you probably won't do that. 2nd option I would do is put two 5k lb axles on it and sell the two you have now. With a 3rd axle on a trailer that short you would need to cut off the first two and re space all three . it also would be harder to turn with the tires sliding sideways as you turn. It would look funny too with 3 axles.
   / Increasing capacity of a trailer #7
I did the same thing you did . Even extended my trailer. It is now 20 ft. I bought 2 new 5200# axles and installed 235x85x16 tires. I think the axle place told me this combo is now rated at 12K. I can say that the springs no longer bottom out when I have my tractor on the trailer
   / Increasing capacity of a trailer #8
Bruce
This is the best option but go for 6000# axles, 5 new wheels, and 5 new load range E radial trailer tires.
You see where I am going. Sell your current trailer and buy a new one. Used trailers sell good.
Chris
   / Increasing capacity of a trailer #9
The best option is to buy 7000 pound axles and be done .
There not that high without or with brakes .
Sent from my iPhone 5 using TractorByNet
   / Increasing capacity of a trailer #10
The best thing to do would be buy a 10k trailer.
2014 Great Dane 53FT Refrigerated Van Reefer Trailer (A51692)
2014 Great Dane...
2011 Kia Forte Sedan (A51694)
2011 Kia Forte...
(INOP) KUBOTA ZD326 ZERO TURN LAWN MOWER (A51247)
(INOP) KUBOTA...
2017 Wanco WSDT Towable Compact Radar-Speed Trailer (A52377)
2017 Wanco WSDT...
2010 Ford Crown Victoria Sedan (A51694)
2010 Ford Crown...
JOHN DEERE 9520 LOT IDENTIFIER 259 (A53084)
JOHN DEERE 9520...
