increase hydraulic pressure
   / increase hydraulic pressure #1
alanjb
North GA
Kubota 3830
Can I increase my pressure to help the FEL and 3pt. I have a L3830 and need to lift 2 hundred more pounds
   / increase hydraulic pressure #2
First, the answer is yes. I also have a 3830. I have had it less than a year and suspect that the relief was set too low.when it went back to the dealer for the first 50 hr service I complained. Book says it should be 2650psi. mine was only 2400psi. It is raised by installing shims of different thickness on the relief spring.
   / increase hydraulic pressure #3
would you have a diagram of the location of the relief spring, some directions. I am not a mechanic as you can tell
   / increase hydraulic pressure #4
I was wondering if you could help me with the exact same problem, I need directions as as I am not mechanical. Maybe you direct me to a diagram?? What ever help you can give me. AJ Ryan
   / increase hydraulic pressure #5
Hello AJ
I'm a mechanic and encourage people to do their own work. The work that Deerlope talks about is quick, easy, and commonly done. But working on the pressure relief valve - which happens to be the primary hydraulic safety valve, BTW - is one of those simple operations that takes specialized tools (gauges & shims) plus some understanding about the forces and hazards involved in changing the settings. I'm sorry; this is one of the few times when you really do need to take it to a real mechanic.
I'd feel more comfortable advising you on how to rebuild just about anything else from steering to starter....and including the engine.
Good luck,
rScotty
   / increase hydraulic pressure #6
The thread was from 2003!
AJRY, please start a new thread, and give us some info on your machine and why you want to increase the pressure. The first step is to get a gauge setup and test what you have to see if it's in spec. We have a video posted on our website showing how to do it-and we offer a ready made gauge as well.
1994 Toyota 6000lbs 2 Stage Forklift (A53472)
1994 Toyota...
2017 Nissan NV200 Cargo Van (A53422)
2017 Nissan NV200...
KENWORTH SERVICE TRUCK (A51406)
KENWORTH SERVICE...
2018 DRAGON ESP 130BBL VACUUM TRAILER (A53843)
2018 DRAGON ESP...
205028 (A52706)
205028 (A52706)
(INOP) VOLVO L70H WHEEL LOADER (A51243)
(INOP) VOLVO L70H...
