Increase height of CK draw bar
   / Increase height of CK draw bar #1
jabelding
Maine
2014 Kioti CK35 2015 CS2410
With a Ball in my draw bar the height is to low for my wood trailer on my CK 35. Does anyone know the part number for the European bolt on bracket to the Kioti CK draw bar as shown in this first post (kubota one). http://www.tractorbynet.com/forums/kubota-owning-operating/200741-what-part.html
I figure if it is rugged enough I could attach my ball to this bracket instead and it would raise it about 3-4 inches witch would be just about right.
Or if anyone has made any height adjustments to their draw bar I would be interested in see what they have done.
I don't want to get a 3pt receiver unit due to the fact that my single Axel wood trailer is sometimes quite tongue light depending on how it is loaded and it is a pain to use stabilizers to keep it down. Just want to have something that is quick and easy to install and remove like the factory tongue.
   / Increase height of CK draw bar #3
I do not know if the spacing for the holes is the same for my DS as you CK, but the draw bar that came with mine has a bend in it so that if you put it in one way it is a drop hitch and the other way it is a raised hitch. You may want to inquire about this draw bar with your local dealer.
   / Increase height of CK draw bar #4
I haven't had any luck finding a part number for a hammer strap, but you might ask your dealer to check. Here are a couple of hammer straps you could build if you wanted to.
2023 RTVXG-850 SideKick (A57024)
2023 RTVXG-850...
202473 (A54757)
202473 (A54757)
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
John Deere 2155 (A53317)
John Deere 2155...
2014 Infiniti QX60 SUV (A53424)
2014 Infiniti QX60...
2015 Ram 5500 Versalift SST-40NE 40ft Sign Bucket Truck (A55852)
2015 Ram 5500...
