In the tire sealant
   / In the tire sealant #1
Deerlope
Veteran Member
Northern, New York
Kubota L3830 03: RTV 900
Anyone one know of a sealant that is put into a tire that stay there forever to seal a leak if one occurs? There are to many draw backs to having foam filled tires.
   / In the tire sealant #2
I have used Gempler's seal for several years. They have two grades, and I use the more expensive one. The only time it has failed to seal is when I got a puncture and shortly thereafter parked the tractor with the puncture up. Apparently the liquid needs to pass over the hole quite a few times to work. In my case, I inflalted the tire and let it sit overnight with the puncture down. The next day it was sealed perfectly. If the nail, etc. stays in the tire, when you remove it you should either run for a while or park with the nail hole down.
   / In the tire sealant #3
I use Green Slime haven't had any problems or leaks with it, knock on wood.
   / In the tire sealant #4
Be cautious as one brand I used ended up being water based and simply froze in clumps in the tire.
Sorry, but do not recall which brand it was.
I will look to see what they offer. Thanks guys.
   / In the tire sealant #7
With hawthorn trees around here, I've used green slime with great success.
Don
   / In the tire sealant #8
I used green slime very successfully until I needed to plow some snow. All four tires went flat shortly after I took the tractor out of heated garage. The slime froze inside the tires and all the thorns started to come out after the tire rubber hardened in freeze. I used whole box of plugs cut in three sections to plug all the holes. The tires looked like a hedgehog when I was done. Does anybody know about freeze resistant sealer?
Now the 64K question what sealant is compatable with Rimgard ballast?
   / In the tire sealant #10
Deerlope, I don't think there would be any tire sealants that will work with liquid tire ballast. It would be too diluted and the tire sealant depends on air pressure to keep it in the tire punture.
The only way you could get liquid ballast and tire puncture together would be to fill your tires with a non water based tire sealant. Which would be cost prohibitive!
Sincerely, Dirt
2016 WITZCO RG-35 RGN LOWBOY TRAILER (A50459)
2016 WITZCO RG-35...
2004 IH 5600l Snow Plow Truck (A52384)
2004 IH 5600l Snow...
New Wolverine72 In Skid Steer Brush Cutter (A53002)
New Wolverine72 In...
11ft S/A Fuel Tank Trailer Frame (A51691)
11ft S/A Fuel Tank...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
