In need of some help
   / In need of some help #1
Inkmann
Western MA
John Deere 2305
I was brooming the driveway with my 52" Quick Hitch Broom and something happened.
The broom has been doing a great job cleaning up the little storms.
Something happened and it's more than a shear pin.
Looks like a broken shaft maybe?
Any help would be greatly appreciated.
Thank you
John
   / In need of some help #2
Is this a Deere or Frontier broom?
I can't tell what's broken from the pictures (pics aren't always worth a thousand words!)
What exactly, are those pictures showing? The one on the right appears to show a pin going through a bushing of some sort. Is there a roll pin missing?
   / In need of some help #3
It looks like you lost bolt 7 (M6 x 55) and nut 9 (M6) To find the drawing go to JDparts, then parts catalog for 2305, then attachments, 52 &60 inch broom, then sectional index, then 52 inch broom, then broom
   / In need of some help #4
You guy's are good!
Anyone have any tips on this fix?
   / In need of some help #6
After further inspection I broke the shaft the tube part #16View attachment 350361
If you can figure out how the #16 tube is held into #14, I think you can figure out how to remove it. Do you know if #16 rotates? The wheel affixed to #14 appears to be chain driven. If #16 is bolted in, should be no problem, but look for a key (if #16 does rotate).
If #14 and #16 are a welded assembly...well, that's probably going to be expensive.
   / In need of some help #7
It looks to me like 16 is a fixed axle and 14 rotates on it (bearings on each end #17).
I think you will find 16 just slides into 14.
Let's hope it goes easy.
2020 MACK PINNACLE DAY CAB (A53426)
2020 MACK PINNACLE...
2004 FREIGHTLINER COLUMBIA (A53843)
2004 FREIGHTLINER...
KUBOTA SVL97-2 SKID STEER (A52705)
KUBOTA SVL97-2...
2018 DRAGON ESP 130BBL VACUUM TRAILER (A53843)
2018 DRAGON ESP...
2019 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2019 HarbinGer V3...
CASE TR310 SKID STEER (A52705)
CASE TR310 SKID...
