In need of sickle cutter bar
   / In need of sickle cutter bar #1
jacobsdaddy06
Bronze Member
NW Arkansas
MF1240
Bought a new idea 256, 3 pt sickle mower obviously well used, well today the bar broke where it attaches to main assembly, anybody know where I might find one? Also would other makes fit or are there universal ones? Thanks
   / In need of sickle cutter bar #2
Not sure what you mean by the 'main assembly', but the bar backbones are usually just soft steel. Line it up using a tooth and bolts (If that's where it broke) slice out a section to fill with weldment, and have it welded back together. Even castings can be welded (nickle rod is my favorite).
A few pictures would make it more clear to us where the break is and the type of fix that could work.
   / In need of sickle cutter bar #3
Check that bar carefully--it may be bent by whatever caused it to break. If the bar is still straight, get it welded. The bar on my MF31 sicklebar that I bought at auction was so bent that it was useless. I got a piece of steel bar from my supplier and drilled holes for the sickle sections and the drive attachment. The cost was low and it just took me a few hours to do the drilling.
2014 FORD F-250 (A50854)
2014 FORD F-250...
GENERATOR HOUSE POEWERED BY TWIN 12.7 DETROITS (A50854)
GENERATOR HOUSE...
BUYERS PREMIUM & PAYMENT TERMS (A51222)
BUYERS PREMIUM &...
2023 AVANT 735 COMPACT WHEEL LOADER (A51242)
2023 AVANT 735...
Big Dog C-146 Zero Turn Mower (A50860)
Big Dog C-146 Zero...
2017 Nitro Z 19ft Bass Boat with 26ft T/A Boat Trailer (A48082)
2017 Nitro Z 19ft...
